Home > My Defender > Ron
Page 3 of 7 <1234567>
When I did mine, I used some of that stretchy Veltrim:
You can't use anything too thick or the trims won't fit back on properly. Darren
Post #982223 12th Feb 2023 10:50pm
Landowner
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
Does it reduce the noise by much?
I watched a YouTube video of a complete sound deadening process, before it was started they measured about 85db of noise, when completed they measured about 75db but the guy stopped talking during the measurement. I rewatched the “before” section and there is a period during the measurement wher the guy stops talking for a second or two….the measurement dropped back to mid 70s !! About a 3db drop only I think.
Post #982225 12th Feb 2023 11:13pm
Drevil
2011 Defender 110 Puma 2.2 USW Indus Silver
I’m doing it incrementally and whilst it’s no S Class, there’s certainly less resonance, creaks and trim rattles.
Oh and no longer issues with winter condensation
Suspect most noise reduction has been offset by the wind noise from the roof rack though!
I’m pleased thus far, feeling less like a tin can in the back.
Post #982229 12th Feb 2023 11:41pm
Remember that a 3dB reduction is actually halving the noise power (the Bel, like the Neper, being logarithmic). A 10dB reduction is very substantial and will generally sound about half as loud to the human ear.
The loudest sound in recorded history, the explosion of Krakatoa in 1883, a bang around 1000 times the power of the Nagasaki bomb, is estimated to have been approx 310dB. It was heard 3000 miles away and the shockwave travelled more than three times round the globe. It killed as many as 120,000 people. Amazon sells an aftermarket vehicle horn advertised to produce a cool 600dB, if true this would note only eliminate all life on earth but would if Einstein is right create a black hole which would destroy the entire solar system. You can buy this weapon of mass destruction for less than £40! Shocked
Post #982233 13th Feb 2023 1:05am
The short answer is yes (as part of a wider treatment - not just those panels).
As mentioned above, the dB scale is logarithmic and so a small change in number reflects a significant one in reality. Darren
Post #982266 13th Feb 2023 11:18am
Procta
Thumbs Up I nearly went for a landy like ron but the 90 version, as i love the colour, but it was lot of money for me to secure a loan for sadly. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #982975 19th Feb 2023 3:04am
Drevil
I knows it’s not 100% necessary, but offcuts make for a good quick arts and crafts session as I move forward in the cabin.
Fitted new door seals all round too, old ones were quite perished. Hopefully stem a few leaks, no doubt cause some new ones.
Post #983042 19th Feb 2023 9:10pm
Drevil
New headlights in. Pretty sure I’ve nailed the alignment vs the previous ones, if not it’s down to the MOT station tomorrow to tweak them.
Wanted to try and avoid ultra modern looking units, just about pulled it off with Trucklites (ish).
Quite pleased with the outcome of a bit of used parts hunting.
Post #985272 12th Mar 2023 4:28pm
Drevil
Arts and crafts continues.
One side now finished, few lessons learned and then on to the other side.
Post #989946 22nd Apr 2023 3:19pm
Interesting that your USW has the small rear windows. Mine has solid panels there so I wonder when they were deleted? Darren
Post #990025 23rd Apr 2023 9:39am
Drevil
I don’t have the original build sheet but I don’t think they were cut in later. Last owner had it from new and nothing on the reams of paperwork to suggest so.
I do like the extra smidge of light and visibility from them.
Post #990029 23rd Apr 2023 10:05am
I know what you mean as the back of mine is very dark, although I have made use of the space on each side for other things. Darren
Post #990036 23rd Apr 2023 10:49am
I can't remember when the rear small windows were deleted, but believe it was a build economy measure but widely welcomed since the small windows are he easiest way to break in to an SW.
Post #990042 23rd Apr 2023 11:35am
Drevil
Trying these fellas in the interior lights…..
Let’s see if they’re too bright or actually allow me to see where I’ve dropped my blooming keys late at night!
Post #990894 30th Apr 2023 4:34pm
Drevil
Not the toughest of tests for towing capacity….
Post #991765 7th May 2023 3:07pm
