Home > Maintenance & Modifications > Penman trailer brake problem
John Bow
Netherlands
Hello,
Help needed!
The brakes of my Penman trailer do not release sometimes. The brake disc have been red hot and smoking several times.
I was suspecting the master brake cilinder so I replaced it. Bleeding the brake lines in order to get air out, gave problems though. Simply no fluid comes out at the calipers..
So, something is still wrong.
Does anyone have an idea of what causes the problem?
Could it be the part on the picture? If so, what is it (a pressure relief valve?) and where can I order a new one (part number)?
Your help is very very much appreciated!
Thanks a lot!
John
Post #983679 25th Feb 2023 9:07pm
rallysteve
That part is a modification which was made to many of the trailers. Its a pressure relief valve which prevents brake pressure exceeding a certain limit. It is intended to prevent the trailer wheels locking under heavy braking.
Previously would have had an accumulator fitted instead.
Is the handbrake correctly adjusted (not too tight)?
Post #983685 25th Feb 2023 9:33pm
John Bow
Netherlands
Hi Steve,
Thanks a lot.
Could this pressure relief valve be defect?
I don’t think it is the hand brake because the trailer can be pushed by hand most of the time. The problem occurs when towing it behind my Defender.
John
Post #983687 25th Feb 2023 9:42pm
John, PM me your email address, I've got all the workshop manuals here for the penman, I'll send over.
Post #983812 27th Feb 2023 8:06am
Devon-Rover
The penman also has a Pivot based pressure relase system on the RH wheel.
According to the AESP this is the bleeding method
9.7.4 Top up the reservoir with brake fluid (refer to Cat 601).
9.7.5 Start at the furthest bleed nipple from the master cylinder (Left-Hand (LH) s1de).
9.7.6 Remove the dust cap and attach a bleed pipe. The other end of the pipe should be
immersed in a container with a quantity of brake fluid_
9.7.7 Open the bleed nipple.
9.7.8 Push the brake operating lever, with smooth even strokes.
9.7.9 Repeat this operation until the air has stopped bubbling from the pipe immersed in the
container.
NOTE
(1) Observe the level in the reservoir and ensure this level does not drop below the danger level
identified on the reservoir body at any time during the bleeding process_
(2) Ensure that the operator topping up the reservoir during the bleeding process does so slowly
to minimise the risk of air bubbles entering the brake system.
9.7.1 0 Once this state is achieved, the brake operating lever should be held at the end of its
stroke (pressure applied). Tighten the bleed nipple.
9.7.11 Release the brake operating lever smoothly.
9.7.12 Check the reservoir, top up if necessary.
NOTE
If no fluid can be passed through the bleed nipple when fully open, the rotating caliper carrier will
require adjusting. This is located on the RH wheel assembly and as will be seen the mechanism is
kept in a biased position by the employment of a compression spring. By screwing in the
adjustment bolt this will increase the compression on the spring. It is recommended that a distance
of 6 mm between the back face of the locking nut and the front face of the boll be employed, which
allows the valve within the valve block to be fully open_ Care must however be taken to ensure that
the spring is not compressed to its coil bound position and therefore it is recommended that a 5 mm
allowance of further travel be left within the spring.
9 7.13 Carry out the bleed cycle on the RH wheel as detailed in Para 9.7.6 to 9.7.11.
9.7.14 Check the reservoir, top up if necessary
Mod lnstr No. Amdt 1
o N v 1
-t -t
ARMY EQUIPMENT 2330-E-202-811
9UPPORT PUBLICATION
9.7.15 With the stone guard removed the auto-reverse valve bleed nipple is on the upperface of
9.7. 16 Repeat the bleed cycle on the auto-reverse valve as detailed in Para 9.7.6 to 9.7.11
9. 7.17 Check the reservoir, top up if necessary
NOTE
To check that the brake system is operating correctly the brake operating lever must be pushed
back f1rmly with the trailer wheels clear of the ground, they should be rotated in the forward
direction and should be met with resistance retarding and stopping the wheels. To check the autoreverse feature -rotate the RH wheel backwards, some initial resistance should be fell at which
stage the valve will shut off the pressure coming from the brake operating lever and allow the wheel
to rotate freely. The LH wheel should also be checked by a second person {it is worthy of note that
if the auto-reverse feature is not initiated by rotating the RH wheel and kept in the reverse position
the LH wheel will be retarded and held in a locked position).
9.7.18 Force the brake operating lever first to its stopped position {brakes hard on), then over to
the master cylinder fully stroked position.
9.7.19 A resistance caused by the internal spring load will be felt against the effort applied,
which should be held for 10 seconds.
9.7 .20 If any air is seen rising from the bottom of the reservoir during and after Para 9.7.19 then
repeat the bleed cycle as detailed in Para 9.7.5 to 9.7.19.
9.7.21 Refit the moisture barrier.
9.7.22 Refit the reservoir cap and outer cover.
9.7.23 Refit the master cylinder top cover.
As seen here > https://assets.publishing.service.gov.uk/g..._Cargo.pdf
Page 445. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #983899 27th Feb 2023 6:52pm
rallysteve
If you are fairly sure that it is not the handbrake mechanism. It is worth checking the adjustment at the drawbar/master cylinder adjustment bolt is correctly adjusted. If that is too far out the brakes will drag and the more they heat up, the worse it will get.
Post #983913 27th Feb 2023 8:46pm
John Bow
Netherlands
Thank you all very much.
The bleeding procedure was performed like described Devon-Rover but we’ll have a look at the rotating caliper. Very helpfull!
My assumption of the pressure relief valve to be defect is not right you think?
Steve, yes there is some space between the draw bar and master cilinder👍
Jim, I will, much appreciated!
Do you all think that the pressure relief valve is not causing the problem?
Post #983922 27th Feb 2023 10:08pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Have you had any luck with this yet?
Post #985340 13th Mar 2023 12:08am
John Bow
Netherlands
Next week we will have a look at it again. I'll keep you posted Thumbs Up
Post #985360 13th Mar 2023 10:56am
LandymanStefan
Well just finishing up an epic road trip in the alps with my penman and this has happened to me now. Coming down one of the last mountains of the holiday and the brakes locked on and cooked. Managed to drag it to a petrol station on the flat to jack it and take the wheels off. Ended up having to crack the brake lines to release the pressure and now we’re driving home unbraked which isn’t ideal but should get us back.
Even melted my nut caps. Will have to bleed and see what’s what when I get back.
Post #1007009 9th Sep 2023 3:48pm
LandymanStefan
After a quick damage assesment today its not looking great. Looks like the whole system really cooked up. The caliper dust seals are burnt and disintegrating, same with the rubber boots on the hand brake cables. So looks like ill have to strip and re build the calipers. I need to check the seal on the back of where the wheel bearing is as i can only assume thats cooked too so thats a full hub strip down to get to it. Also the return line from the prv box has melted the moisture barrier/diaphram in the resevoir when it was returning the boiling fluid back in there. Big Cry
I have a few questions for the folk out there that hve done a fair bit of work on the penmans. Does anyone know the part number of the rubber diaphram for the resevoir? I know the master cylinder is a girling 75 but that alone doesnt come with the resevoir cup and barrier.
Another thing is what grease is used when re packing the wheel bearings?
Are the brake calipers just standard xantia fronts so i can buy a re seal kit for them?
Post #1007887 16th Sep 2023 10:59pm
Mother superior
Watching this one with interest, I’m sure my Penman brakes need a total overhaul. But I’m struggling to find rebuild kits for master cylinder/callipers.
Wes Oh woe, oh woe
My crusty old landrover,
It will not go.
Post #1008733 24th Sep 2023 9:27pm
LandymanStefan
Im currently midway through the rebuild. I’ve removed one caliper and rebuild it and removed the hub on that same side to check the rear bearing seal condition given the brake caliper seals were cooked.
The brake caliper rebuild was very straight forward, I bought a re seal kit for a xantia front caliper. One of the sliding pin gaskets was the wrong size but the company rectified this for me. I did order a package which showed it including the large cover that goes on the back of the caliper and protects the hand brake mechanism however this wasn’t included when I received it and they didn’t have this cover so they are going to refund this set and I purchased from another seller. The piston itself unscrews and screws back in which makes the job quite easy and minimal tools required.
The hub seal was in good condition which I was able to see after removing the hub. I re packed the wheel bearings with grease and re assembled the bearings as per some defender manuals. I tightened to 60nm to seat the bearings then backed off, i then re tightened to 10nm and it felt great, no play and freely spinning. It does feel more loose/free than how it was originally set but I believe it feels fine and I’ll keep monitoring it.
I’m hoping to get the other caliper re built tomorrow then I’ll try bleeding it on the weekend.
The master cylinder is another off the shelf part, it’s girling 75 so I imagine you’ll be able to get a seal kit for it.
I am occasionally in contact with a guy that works on bases as a mechanic and he said as long as the auto reverse valve isn’t faulty you should be ok. He said when they have trailers with the auto reverse valve faulty they have to write off the trailer as they can’t get any parts and haven’t been able to since penman went bust and got bought out. Even parts such as caliper seals etc that we can buy on civvy street, they can’t get hold of as they’re only approved to get the stuff from penman which don’t exist in their old form.
A few pictures from the work so far
Re sealed caliper
Hub seal check and re build
Post #1008868 25th Sep 2023 9:29pm
Mother superior
Many thanks for that Landy Man Stefan, I’ll start sorting some bits
Wes Oh woe, oh woe
It will not go.
Post #1009194 27th Sep 2023 9:26pm
LandymanStefan
Well I completed the caliper rebuild on the other side too. Re build the wheel bearing on that side as well, it also needed a rear hub seal. To be honest I’m quite glad it forced me to rebuild the wheel bearing as they were set very tight how I received it. Had my old man to help me bleed the system as per the notes someone left above and everything now works fine!
Very happy that both the pressure relief valve and auto reverse still work as I was worried these are extremely hard to find. I think I may have to back the bolt off that engages the master cylinder as I think it’s engaging a little early for my liking.
Had it out on the weekend and all was well (with the trailer that is suspect cracked td5 head now though) Rolling Eyes
Post #1011014 12th Oct 2023 6:05pm
