Home > My Defender > Baltic blue 110usw
Page 11 of 15 <123 ... 101112 131415>
Siwynne
That’s interesting. I will build with the new one I have and investigate the different pump options for a future swap.
Post #972851 29th Nov 2022 6:43pm
Siwynne
Had a couple of hours at it. And crank is back in with pistons and bottom end buttoned up. Head has been cleaned of massive amounts of carbon. The egr is getting blanked and deleted. Valves have all been cleaned and lapped. If this doesn’t make a huge difference to performance I’ll be surprised. New oil pump is in. Citroen makers mark, last one was fomoco.
Post #973341 3rd Dec 2022 8:08pm
Screbble
Great progress - and probably very therapeutic…
As you anticipate, you’ll notice the difference when it’s all up and running.
Watch the Magpies don’t steal those valves👍
Post #973356 4th Dec 2022 9:17am
Dinnu
Good progress Thumbs Up
I was under the impression that the DPF works in conjunction with the EGR amongst other things. But glad to be corrected. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #973358 4th Dec 2022 10:17am
Siwynne
I will speak to a remap co tomorrow but Ive rebuilt a couple of engines in the past but never one with an egr. The carbon was unbelievable. If it can go it’s going
Post #973360 4th Dec 2022 11:01am
Siwynne
The instructions with the new pump say to fill it with a heavy gearbox type oil to ensure it primes. I intend to do this upside down via the pick up tube then put the sump on and turn it back over to avoid spillage. Can anybody foresee an issue doing this way
Post #973367 4th Dec 2022 1:33pm
Siwynne
Cleaned and refitted the inlet manifold last night. The carbon and junk in there was so wrong. It took an hour and a half with bottle brushes and over cleaner then pressure washing to get it near clean.
Egr is definitely being blanked and mapped out having spoken to a number of tuning companies it is common practice
Post #973597 6th Dec 2022 12:05pm
geobloke
I am a big big fan of this Lucas oil stabiliser for assembling components like this.
https://www.amazon.co.uk/Lucas-Oil-10001-H...B000AS1XYO
It is slightly sticky so provides that instant lubrication on startup, it also has the added advantage of not dripping on you if you are underneath it or spilling over your worktop.
The equivalent is the Lucas assembly lube. Both work well.
https://www.amazon.co.uk/Lucas-Oil-10152-A...&psc=1
Post #973614 6th Dec 2022 1:41pm
geobloke
Ha I know how you feel. I recently cleaned out the inlet manifold on my Freelander 2 TD4 and blimey as with yourself absolutely caked on in there... Blanked off the EGR at the same time and would you believe it the combination of a clean inlet manifold and no EGR gasses and the engine starts better and is more perky Thumbs Up
Post #973615 6th Dec 2022 1:44pm
Siwynne
I regularly rebuild air cooled Vw engines so have a similar assembly lube to hand. Similar to smooth strawberry jam. This is taking significantly longer than the Vw ones take me
Post #973667 6th Dec 2022 6:11pm
geobloke
In which case i shall not offer you any more eggs to suck... Rolling with laughter Rolling Eyes
Post #973674 6th Dec 2022 7:14pm
Siwynne
This arrived today so that’s tonight’s job. Hope the turbo is not beyond repair.
Post #973692 6th Dec 2022 8:05pm
Dinnu
Seems to match what was said on the site I linked in an earlier post regarding the vane pumps, where there is a 10minute oil drain limit, whereby it can potentially air lock and not build pressure if the pump is not re submerged in oil.
So I guess after priming with heavy oil, and putting in the sump, as soon as you rotate right side up, better fill up with oil. Just don’t forget to keep it always upright! 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #973710 6th Dec 2022 8:56pm
Siwynne
All comment and advice appreciated
It may be something I’ve missed and that would be galling if it doesn’t work when it goes back in
Post #973736 6th Dec 2022 9:47pm
Siwynne
Pump primed. And plenty of assembly lube used everywhere else. Hope it’s enough to keep everything slippy
Post #973757 7th Dec 2022 6:28am
