Home > Wheels & Tyres > The Wolf steel wheel appreciation thread
Page 34 of 44 <123 ... 333435 ... 424344>
Van Diesel
United Kingdom 1986 Defender 90 V8 Petrol ST Auto Pennine Grey
Will the Wolf wheel take a 255/85 tyre? I think most are 235/85 but can get the 255's for a good bit less. 21 Defender D300 H/Top
63 FFRR SDV8
86 90 Pick Up 3.9 V8
Post #971159 14th Nov 2022 9:36pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Yes they will.
I have 255/85 KM3’s fitted to mine, picture is a few posts back for reference. Thumbs Up 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #971162 14th Nov 2022 10:03pm
Van Diesel
Ah, perfect answer. Are yours original wolfs? Just wondered if they'd rub at all but should still be plenty of space. 21 Defender D300 H/Top
63 FFRR SDV8
Post #971169 14th Nov 2022 10:31pm
db950
Hi, yes original LR Wolfs
They will rub on your radius arms, just need to adjust the steering stop bolts to suit. 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #971170 14th Nov 2022 10:36pm
murph81
Ireland 2007 Defender 110 Td5 PU Belize Green
I have a set of ex PSNI Tangi wolf steels, they are quite rusty.
I'd like to have them painted the same white as the roof on by Belize green 110.
Whats the correct colour code?
Post #971778 20th Nov 2022 10:38am
Van Diesel
They say if it sounds too good to be true it normally is, hence my hesitation on this advert.
However at £129 incl P&P for 4 x new genuine wolf wheels it seemed worth a punt. Description said a pallet had fallen over and some of the wheels were damaged. Nervously opened the boxes finding a scuff on the first 2 and a dented rim on the 3rd followed by a scuff on the last one. Pretty happy.
I think the dent can be knocked out at a tyre place and as I'm changing the colour of them the scuffs don't matter. If the dented one was a write off it's still cheap for 3. First bit of luck I've had in a while.
63 FFRR SDV8
Post #971840 20th Nov 2022 9:06pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
Genuine Wolf's ( anr4583) with longer studs and 255 85 r16 Toyo Open Country MT's. The body is tarpaulin grey with limestone top and wheels.
Post #973000 30th Nov 2022 9:42pm
murph81
That looks perfect, was hoping to see those tyres on genuine wheels on a 110.
I'll be going for the same combo.
I always like that size tyre on the Brooklyn Coachworks Defenders.
Post #973012 30th Nov 2022 11:27pm
JOW240725
They do look perfect! I think they look better on the narrower rim, I think they're a little balloon looking on my ANR's. Might have to try a swap.... James
Instagram @suffolk_rovers
Post #973038 1st Dec 2022 9:47am
MarkBrown
Brooklyn coachworks do some lovely Land Rovers.
Post #973115 1st Dec 2022 8:17pm
silvermilnec
Wow what a long thread 😂
I’m looking to get some genuine wolfs.
Does anyone know what stamps should be on each wheel?
Much appreciated 👍
Post #974502 13th Dec 2022 9:28am
MarkBrown
ANR 4583
Post #974598 13th Dec 2022 9:27pm
silvermilnec
Thanks Mark!
Should there be something stamped between each lug, so 4 stamps on each wheel?
Would you know the going rate for a set these days?
Cheers Chris
Post #974623 14th Dec 2022 10:02am
Dinnu
Have a look at this site https://www.landroverexpedition.com/equipment/wolf-wheels/
As I am not the owner of the site, I cannot guarantee correctness, but good as a starting point.
I have a set of aftermarket rims, and they seem to be well built and my guess is they are stronger than the axle itself. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #974630 14th Dec 2022 11:51am
MarkBrown
The number is stamped on the rim, its says anr4583 tubeless. There was a set on Ebay for £200, but they were powder coated black, which is fine, if you want black! About £300 plus for 4 is about the going rate, depending on condition. Good luck in your search. Thanks Mark
Post #974631 14th Dec 2022 11:52am
