Home > Maintenance & Modifications > Indicators work, but one side doesn’t flash when locked
Page 2 of 2 <12
Good luck. It’ll be somewhere.
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #970885 12th Nov 2022 2:52pm
As I said earlier, check your fuses. It'll be something related to the alarm. Darren
Post #970889 12th Nov 2022 4:55pm
Ianh
How long ago did you change your key fob battery, does the same issue occur with your other fob?
I have a vague recollection that a low fob battery can cause just one side of the indicators to blink when locking vehicle, alerting you to the fact the fob battery is low.
Post #970892 12th Nov 2022 5:20pm
Co1
That’s interesting Ian and would be a nice easy fix! Haven’t changed the battery in a while. I’ll try the spare set tonight.
Post #970905 12th Nov 2022 7:09pm
Ianh
It might be that both indicators don’t flash with a low battery, but I just can’t remember...worth a punt
https://www.defender2.net/forum/topic65289...+indicator
See this also
Post #970913 12th Nov 2022 8:07pm
Co1
Tried the spare set to no avail! Will start checking the wiring. Censored my back up last weekend, so rolling around under the landy is far from ideal!
Post #970925 12th Nov 2022 9:13pm
Co1
Checked the lamp connections and all OK. Looking at the drawings, the 0V is common whether the signal comes from the indicator stalk, hazard warning switch, or the alarm system. It works OK via the first 2 with the engineer not running so must be the signal from the alarm system. I will test the output on pin 1 on the ECU alarm module and then go from there. Anyone got any ideas where this module is?!
Post #970967 13th Nov 2022 2:03pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Remove the loudspeaker under the steering wheel.
You'll find this (LHD photo, your loom routing and mount position will be mirrored):
Green plug wiring:
Post #970982 13th Nov 2022 5:21pm
It’s not unknown for wet to get there, and we have had a lot of rain.
So keep an eye out for wet or pin corrosion. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #970986 13th Nov 2022 5:27pm
Ianh
The component called the alarm ECU on the diagram you posted is either a Lucas 10AS (Green) or one of the 2 later ALM ECU’s (black). They are different but the input and output wiring is the same and they are in the same location.
That location is in the driver footwell above the pedals to the right of centre. You can see and gain access to it by removing the divers footwell speaker.
Remotekey have some useful pictures showing location and connectors https://remotekey.co.uk/land-rover-keys-re...larm-ecus/
Post #970987 13th Nov 2022 5:32pm
Co1
Awesome info guys, much appreciated.
Post #971005 13th Nov 2022 7:10pm
Co1
Had a quick look this morning. Found the connection and it looks like there might have been an element water ingress. However I couldn’t get a test probe onto it without resorting to contortionist movements, and my back is goosed at the moment so it will have to wait.
Post #971786 20th Nov 2022 1:02pm
Yes, I know the exact area you mean and it’s be all to easy to do your back in getting at it too! A real pain of an angle.
Damp can be a real problem. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #971809 20th Nov 2022 4:02pm
Page 2 of 2 <12
