Home > Maintenance & Modifications > Indicators work, but one side doesn’t flash when locked
Co1
Odd one, but hopefully I’m not the first. This is on a puma. All indicators work individually but when locking/unlocking only the passenger side flash. Any ideas?
Post #970659 10th Nov 2022 6:32pm
Do they all work with the hazard switch? Darren
Post #970691 10th Nov 2022 9:59pm
Co1
Good question! Yes, hazards are fine also.
Post #970703 10th Nov 2022 10:43pm
In that case, check all of the fuses, particularly any that are associated with the alarm, of which there are several. I once caused a short circuit whilst changing an indicator light and eventually replaced four different blown fuses before I could get the alarm to flash the indicators properly. Darren
Post #970710 10th Nov 2022 11:07pm
Ground eyes loose on the RHS of the transfer box, there are two eyes on a single M6 or M8 stud there, one ground eye for each side. One probably has decent connection the other probably doesn’t.
They come loose over time, best to clean up. Nip the bolt up but not too tight and apply a tiny bit of low strength loctite such as 222.
Alternatively, find a good grounding point, and using a multimeter (keep lights off) do a continuity check on the lighting ground pin. The reading should be very low, if it’s high or significantly different one side to the other it’s likely to be the ground stud eyes.
This is providing it is a ground issue, if it’s a power issue the relay maybe culprit.
Grounding issues are most common.
Hope that might help, I had the hex flanged stud come loose with those two eyes twice. And it would come out if any clutch is replaced or anything like that.
The small amount of Loctite 222 solved the issue.
It still came loose even when torqued to spec.
It’s possible so this is why I am mentioning it, also you’ll likely find it gets worse and also it’s worse without the engine running as the voltage is a couple of volts less. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #970807 11th Nov 2022 7:22pm
Co1
Thanks Steve. The bit I can’t get my head around is how they function perfectly fine as indicators or hazards, but not when locking or unlocking. Is there a separate supply and earth for this function?
Post #970815 11th Nov 2022 7:49pm
Ianh
On the 10AS there are separate wires that trigger the left and right indicators . See https://www.nanocom-diagnostics.com/upload...0Guide.pdf
Page 5, green connector, pin 1 and pin 6.
So a case of looking at the wiring diagram to see where those wires go and if there is a break in the route from pin 1.
Post #970816 11th Nov 2022 8:06pm
CO1 - Difference in supply voltage, which engine off alternator isn’t making charging current and voltage
At rest circa 12.6v approx, with engine running 14.5v approx.
The difference in voltage overcomes the high resistance with a bad ground, not always but a dodgy grounding point it can do.
As I mentioned, one grounding eye on the stud probably has lower resistance than the other which is why one side is working fine with engine on or off. The other probably has high resistance, loose or dirty connection eye.
Thumbs Up As the two ground eyes are separate for each side, and not shared that may explain the one sided lighting. (The ground stud is the same, but the two separate ground feeds are for each side).
The area is exposed to all elements and high vibration.
If it isn’t this then I’d change the relay, but the ground is more probable. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #970821 11th Nov 2022 8:46pm
Co1
Makes perfect sense Steve, thanks for that.
Post #970826 11th Nov 2022 9:24pm
Ianh
You could test Steve’s hypothesis by trying indicators and hazard switch with ignition on but engine not running.
Post #970827 11th Nov 2022 9:39pm
Co1
Hazards work fine with ignition off Neutral
Post #970873 12th Nov 2022 12:31pm
Different circuit paths though.
Test the ground pins for continuity against a good clean chassis earth. Also test voltage in each scenario but use a chassis Earth not the Econoseal socket ground.
Is it LED lights or standard? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #970876 12th Nov 2022 12:55pm
Co1
Thanks Steve. I’ve cleaned up the ground on the side of the transfer box and it’s still the same. It’s standard lights, not LED. are there separate fuses for the two circuits, it doesn’t look like it when I check the Haynes manual.
Post #970879 12th Nov 2022 2:00pm
Check the voltage on each side and compare, in particular the scenario when it does it.
Each flash should momentarily hit at least 12.2v definitely not less than 11.8v. With the engine not running.
I know it’s not easy to hold the probes and mimic the locking at the same time.
If you had a couple of Econoseal male pins some crocodile clip tests leads and a multimeter it would be helpful.
Are you sure none of the connections have came off or loose on the indicator stalk?
If you want to continuity check each wire run, the reading should be as close to 0 Ohm as possible if it’s high there is a possibility there is a wire break.
Are the side repeaters connector okay? Not corroded or wet ?
Bayonet fittings not corroded or wet ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #970880 12th Nov 2022 2:13pm
Co1
Hi Steve. Thanks for the advice. I’ll work through it this weekend.
Post #970881 12th Nov 2022 2:15pm
