![]() | Home > V8 > Stage One V8 4.6 GEMS Build |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Happy to help.. there’s a few on here who have great knowledge. QRZ 2e0vpf |
MercianRover Member Since: 07 Apr 2022 Location: Culworth Posts: 166 ![]() ![]() ![]() |
Thermal switch adapter for bottom hose: https://foundry4x4.co.uk/index.php?route=p...uct_id=133 My thermostat is whatever was standard for 3.9 EFI on 14CU. Factory knew what they were doing. O/T: keep the paper element airbox and filter. |
cartoonhead Member Since: 02 Mar 2018 Location: Bucks Posts: 135 ![]() ![]() ![]() |
Long overdue update! Engine is in, all the plumbing is done. It’s not the prettiest setup but it’ll do the job. Next job is to sort out an exhaust and figure out what some of the wires do.
![]() Click image to enlarge @tab.travels on instagram Defender 130 2.2 TDCI Defender 90 TD5 80" CCV Trialer 4.6 V8 (14CUX) Stage One V8 109 - 3.5 V8 Stage One V8 109 - 4.6 V8 (GEMS) - in progress Range Rover L322 4.4 TDV8 Freelander 1 2.0 TD4 |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6216 ![]() ![]() ![]() |
Nice.
Long overdue update: With the help of the Rover V8 Appreciation group on FB, I think I've sorted the last few niggles with this. She's running nicely and pulls like a train. I really need some taller gearing next.
The engine bay is a bit scabby, but here she is all plumbed up: ![]() Click image to enlarge Once I've got the taller gearing I'll work out what MPG I'm getting ![]() Defender 130 2.2 TDCI Defender 90 TD5 80" CCV Trialer 4.6 V8 (14CUX) Stage One V8 109 - 3.5 V8 Stage One V8 109 - 4.6 V8 (GEMS) - in progress Range Rover L322 4.4 TDV8 Freelander 1 2.0 TD4 |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 ![]() ![]() |
Change the transfer gearing in the LT95 to Range Rover ratios, will transform it!
