![]() | Home > Puma (Tdci) > Engine, Gearbox & Transfer Box Oil Change |
| Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 371
Under bed storage boxes make a good drain pan, collecting drips over a wide area.
Click image to enlarge It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
| nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 |
Your a brave man with that set up I think i would need a drain spigot or the drive would look like a Jackson pollock and her in doors would get creative with my testicles.........not in a good way
| MussEd Member Since: 20 Feb 2013 Location: East Lothian Posts: 376
Did mine today with help from this thread and a couple of others. Thanks to all who contributed.
Gearbox by far the most awkward but got there in the end! |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2541
If by awkward you mean filling the gearbox, by far the easiest way is to get circa 1.8m of 12mm od clear tube, feed into the filler hole from the engine bay ensuring no dips and it’s supported, place a funnel in the tube, measure your oil in a measuring jug, pour the oil and let gravity do the work. Cheap, simple and accurate.
| nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 80
Hello everyone
I have just had my gearbox changed, I had the oil changed a few years ago, I have drained almost 3 liters. I had unscrewed the filling screw and the oil flowed at this level. I added Kennol 75w FE oil using the syringe with the 500ml elbow tip so I refilled it about 4 and a half times. which makes around 2,250l in the gearbox. the oil has the following specifications SAE 75W- API GL-4/GL-5/MT-1 PSA B71 2310 MERCEDES MB 235.73 FORD WSS-M2C200-D2 |
| Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 180
Hi Have been given two options for the Diff oil on our 2.4 puma
Could anyone recommend an oil that i could use in my diffs/trans/gearbox? many thanks Last edited by Naycrx on 26th Mar 2024 5:12pm. Edited 1 time in total |
posted twice
| X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304
Hello Naycrx
I used this on our 2.4 Pumas Motul Gear 300 / SAE 75W90 Gearbox (MT82) Transfer box (LT230Q) Front and Rear Differentials https://www.defender2.net/forum/topic84159.html From Site Sponsor Opie Oils https://www.opieoils.co.uk/p-899-motul-gea...antid=1131 Good Luck... https://www.defender2.net/forum/topic83242.html |
so 10 litres of this ? should do all of it ?
Hello Naycrx
Yes... Click image to enlarge I did an All Fluids Service at 30K on my 90 As my 90 is now approaching 60K and my wife's 110 has just turned 30K I have taken delivery of one of these... Click image to enlarge Check on Pricing with Opie as it looks as though currently 20X1 Litre bottles are cheaper (£10) than a 1X20 Litre Container. Opie regularly has 5% + discount offers, so choose your timing or ask for D2N discount when calling. https://www.opieoils.co.uk/p-899-motul-gea...antid=1131 Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
| InternationalDBA Member Since: 18 Feb 2018 Location: West Sussex Posts: 41
It worked with a 2008 Puma. That was how I did mine although I used copper pipe with a 90 degrees joint at the end. |
I do the same on my 2.2 Puma . I use a 1.2m length of 12mm outside diameter clear plastic tube with a funnel connected from the engine bay, worked perfect to fill the gearbox and very easy to do. Just measure the exact quantity of oil ( 2.2L for 2.4 and 2.4L for 2.2 according to manuals !!!) you need and as you say, let gravity do the work.
| keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2279
Can I use this in my puma 2.2 gearbox, transfer box, diffs?
Click image to enlarge |
^should it be fine?
