![]() | Home > Technical > LR038612 - DEFENDER FRONT WING SEAL |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2289 ![]() ![]() ![]() |
Thank you
GuJa Member Since: 03 Oct 2017 Location: Elsfleth Posts: 21 ![]() ![]() ![]() |
Hello,
I just found on ebay a possible alternative. I ordered already 1 m for 12 € and will keep you informed if my 90 will be happy with this additional sealing. ![]() See: https://www.ebay.de/itm/323774246804?hash=...BM1PaI7vNg |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2683 ![]() ![]() ![]() |
Looks like an industrial garage door seal.
Whats its actual purpose?.....says the bloke with a TD5 |
Famous Four have a nongenuine version if that's any help.
https://www.famousfour.co.uk/new_parts/ff_part?part=30547 |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 877 ![]() ![]() ![]() |
Is there anything suitable available on this website?
https://coh-baines.co.uk/ |
chek Member Since: 17 Sep 2015 Location: ZRH Posts: 183 ![]() ![]() ![]() |
Looks promising! ![]() |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
its a very unusual shape and i have searched on line for a long time and i have not seen a profile like it ![]() the closest i coulf find is this ![]() Click image to enlarge but the it costs £4 on e bay but postage from Europe is £20....... there are a few on e bay with profiles that might work ... ![]() Some folk on here have used d shaped rubber seal on the bonnet and i wonder if that may stop the ingress.....i personally wont pay 50 notes for 16inches of rubber ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
^^^ That was me and yes it does
![]() https://www.defender2.net/forum/post945800.html#945800 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
just a post 2012 bodge to stop water getting to the heater inlet and floormat on the passenger side.If i only had one i would put it at that side. LR Anoraks D rubber to the bonnet fix should solve the problem as well! |
That might work ..might be a loose fit but you could silicone it in place ..it looks as though for a short piece you could bend it over in a vice to look a little like the original!Its very strange that LR look to have had a bespoke profile made rather than use something of the shelf?Im sure the exact profile is out there somewhere ion a FORD or dusty Rover shelf. |
In the meantime, I got the seal and installed it. I did not use any Sikaflex or similar in the first step (I'll give it a try). In addition to the seal, I also took an old bicycle inner tube and glued a part of it from the gutter to the wing. Now the water is no longer running into the engine bay.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
great fix
I'm going to do this.... OK mine is a TD5 but anything to direct water away has to be a good idea
Rich1968 Member Since: 03 Nov 2013 Location: Towcester Posts: 87 ![]() ![]() |
