Home > Puma (Tdci) > Injectors replacement |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3210 |
I believe that for the 2.4, you can use FORscan, which is the application for Ford. That should have the injector coding function.
Not for the 2.2 unfortunately. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
15th Sep 2022 12:35am |
It's well documented on here that the relearn process is unnecessary. The system sorts itself out in due course. Darren
15th Sep 2022 6:47am |
HardCharger Member Since: 03 Mar 2013 Location: Manila, SFO, Amsterdam Posts: 678 |
I think he meant telling the ECU that there are new injectors and which injectors are where.
IIDTool BT from Gap Diagnostics works for me |
15th Sep 2022 7:17am |
Ah, yes they need coding but the VCV doesn't need the relearn process, despite what the manuals might say. Darren
15th Sep 2022 8:37am |
Rivarama Member Since: 28 Aug 2021 Location: London Posts: 155 |
Just called PF Jones and they told me those Denso injectors do not need to go through the relearn process. Just plug and play…
They also absolutely certified me that the Denso VCV didn’t need a relearn either… I am confused. Is that true? Neither need a relearn?? |
15th Sep 2022 3:59pm |
No need to relearn the VCV as they will self learn over time.
BUT! You do need to tell your ECU that there are new injectors and where they live. If you do not do this, the ECU will still recognize the old injectors and may refuse to work since it doesn't know the new ones. You need to input each serial number (?) of each injector at the corresponding order they are inserted. Since you will be doing this anyway, and you already have the diagnostic tool in there, might as well do the relearn. If you opt out on this step, no biggie. |
16th Sep 2022 2:44am |
