![]() | Home > For Sale & Wanted > [SOLD] 'Refurbished' Mantec Plastic Snorkel |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
This is the traditional looking plastic snorkel, as fitted to G4 vehicles amongst others. It will fit 300tdi, TD5 and Puma vehicles.
I bought the basic snorkel very cheaply on here a few weeks ago, to which I've added a new stainless grill to the mushroom top, blackend stainless jubilee clips and a new fitting kit, with the intention of fitting it to my own 110. I've also made a new windscreen bracket out of stainless angle, which is drilled to fit to the snorkel body only as I planned to use Sikaflex to stick it to the windscreen frame. I've even painted it to match! However, I've discovered a compatibility problem with something else that I planned to fit so it's no longer of use to me With all of that in mind, I'd like £85 for the complete kit as shown. For any other vehicle, this includes everything required to bolt it straight on. Fitting instructions are available to download from the Mantec website. It can be collected from Deepcut, Surrey or I can post for an additional £8. Thanks for looking. Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia Last edited by LandRoverAnorak on 17th Jun 2019 9:35pm. Edited 1 time in total |
Potentially, yes. Where do you have in mind? Darren
Bump
| MalteseRover Member Since: 02 Jul 2013 Location: Gozo Posts: 137
hello, i am just looking for some info on the metal bits inside the snorkel.
how do these get fixed in it? Click image to enlarge thanks Joseph |
Hi Joseph,
The part with four vanes is fitted into the top of the tube and then the mushroom top fits over it. I don't recognise the other bit, I'm afraid. You can find a copy of the fitting instructions here, in case that helps: https://www.defender2.net/gallery/albums/u...ctions.pdf Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Hi!
thanks. i was guessing it fits in the tube on the elbowed side but is a loose fit. do you know if it has to be clipped or secured with something? the C ring was in the mushroom when i got it. i thought it was a shim between mushroom and tube but it is too tick for that. thanks for the manual! have a good day. joseph |
Once slotted into the top of the tube, the vaned part is held in place by the mushroom top. Darren
| Gasket Member Since: 30 May 2020 Location: Manchester Posts: 632 |
Darren - sorry to resurrect a very old for sale post, but rather than start a new thread I thought I'd recycle this one.
Could you (or anyone else) tell me where you found the stainless grille? I've been looking everywhere and can't seem to find one. I'm an inch from drawing it up and having it laser cut. |
I think it came as part of the new fitting kit. I haven't got a record of buying it separately from the rest of the kit, which was only about £19 from Mantec at the time. I don't know whether they're still available, though. Darren
Thank you very much.
Its due for delivery today so I'll have a check to see if anything else is missing and then I'll give the people running the mantec site a call. |
