Home > For Sale & Wanted > [SOLD] 'Refurbished' Mantec Plastic Snorkel
This is the traditional looking plastic snorkel, as fitted to G4 vehicles amongst others. It will fit 300tdi, TD5 and Puma vehicles.
I bought the basic snorkel very cheaply on here a few weeks ago, to which I've added a new stainless grill to the mushroom top, blackend stainless jubilee clips and a new fitting kit, with the intention of fitting it to my own 110. I've also made a new windscreen bracket out of stainless angle, which is drilled to fit to the snorkel body only as I planned to use Sikaflex to stick it to the windscreen frame. I've even painted it to match! However, I've discovered a compatibility problem with something else that I planned to fit so it's no longer of use to me Rolling Eyes
With all of that in mind, I'd like £85 for the complete kit as shown. For any other vehicle, this includes everything required to bolt it straight on. Fitting instructions are available to download from the Mantec website.
It can be collected from Deepcut, Surrey or I can post for an additional £8.
Thanks for looking.
 Darren
Post #776386 6th Jun 2019 5:05pm
MK
Can you drop it off nearby? Puma 110" SW
Post #776618 8th Jun 2019 3:54am
Potentially, yes. Where do you have in mind? Darren
Post #776627 8th Jun 2019 7:18am
Bump Smile Darren
Post #776976 10th Jun 2019 9:38pm
MalteseRover
Malta
hello, i am just looking for some info on the metal bits inside the snorkel.
how do these get fixed in it?
thanks
Joseph
Post #791286 8th Sep 2019 9:08pm
Hi Joseph,
The part with four vanes is fitted into the top of the tube and then the mushroom top fits over it. I don't recognise the other bit, I'm afraid.
You can find a copy of the fitting instructions here, in case that helps:
https://www.defender2.net/gallery/albums/u...ctions.pdf Darren
Post #791291 8th Sep 2019 9:19pm
MalteseRover
Malta
Hi!
thanks. i was guessing it fits in the tube on the elbowed side but is a loose fit. do you know if it has to be clipped or secured with something? the C ring was in the mushroom when i got it. i thought it was a shim between mushroom and tube but it is too tick for that.
thanks for the manual!
have a good day.
joseph
Post #791329 9th Sep 2019 6:46am
Once slotted into the top of the tube, the vaned part is held in place by the mushroom top. Darren
Post #791343 9th Sep 2019 8:15am
Gasket
Darren - sorry to resurrect a very old for sale post, but rather than start a new thread I thought I'd recycle this one.
Could you (or anyone else) tell me where you found the stainless grille?
I've been looking everywhere and can't seem to find one. I'm an inch from drawing it up and having it laser cut.
Post #959835 28th Jul 2022 2:20pm
I think it came as part of the new fitting kit. I haven't got a record of buying it separately from the rest of the kit, which was only about £19 from Mantec at the time. I don't know whether they're still available, though. Darren
Post #959840 28th Jul 2022 2:51pm
Gasket
Thank you very much.
Its due for delivery today so I'll have a check to see if anything else is missing and then I'll give the people running the mantec site a call.
Post #959841 28th Jul 2022 2:55pm
