![]() | Home > Td5 > Anti roll bar installation |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
This is mine rear ARB if it helps.(TD5 110)
The gap will closed up as you tighten up the bolts. From memory when I did mine (standard bushes) I did the bolts up in an even fashion to close the gap up. ![]() Click image to enlarge 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 292 ![]() ![]() |
ok thanks, looks like youve got more room between the ARB and the fuel tank cover. Just need a couple more nuts then ill tighten things down and see what happens Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Alex,
You dont have a suspension lift on yours do you? The higher the rear suspension, the more rotated the rear ARB will be and the closer it will be to the tank cradle. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
Hi,
Nope bog standard (at moment) when it comes to suspension. Uprated normal height springs and Koni shocks in the pipeline Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
Your front one is incorrectly installed anyway. At the front, the ARB end of the drop links should be the top, the axle end of the drop link the bottom (The front ARB should be above the track rod). For the rear ARB it is the other way round. |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 529 ![]() ![]() |
Front bars on upside down, should be above track bar too
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3336 ![]() ![]() |
Looks like you've fitted the front ARB drop links below instead of above the mountings. lf it makes you feel any better, l did exactly the same when l installed mine.
I also had the same issue with the rear ARB touching the fuel tank cover. Eventually l binned the Britpart and fitted a genuine Land Rover rear ARB and that was fine, didn't touch the cover. |
Many thanks everyone, much appreciated . Help i get from this list is just what I need. ok can fix the front.
All i can say is a picture would have been worth 1000 words ... pity britpart didnt put an in their fitting instructions ! sadly, re the rear, unless done sonething stupid (again) even the LR part is too near the fuel tank cover, there is about 3mm between the bar and it. if the bar twists then its going to push against the fuel tank Rgds Alex Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
Hi Johm. Quick question. you've got loads of space between tank and ARB but looks as if you don't have the fuyel tank cover there. Is that the case? Rgds Alex Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
It's easy to make some spacers to fit between the rear bushes and their mounting brackets to drop the bar away from the tank.
For the record my 2007 110 was identical to John's (with the rather feeble and rust-prone LR tank guard) and had similar clearance to that in the photo. I subsequently fitted a YRM alloy tank guard (infinitely better than the original) and that fits with clearance too. I'm not sure why yours is so different, but anything is possible with Britpart. |
yesh, but a LR version was as bad Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
ok my tank guard is on its last legs as well, ill look at the YRM guard thx Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1905 ![]() ![]() |
This is what I did. I found that, when the car was more than lightly loaded, the standard ARB would foul the tank guard. I just got some bits of 10mm alu and cut them to shape - easy enough with the tools I have. If they ever need replacing I could do them in something else but a couple of years in they're fine. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Course if I'd looked at the LRWorkshop site the diag shows the correct way to mount the ARB
![]() I'll get the front sorted then mesure up some spacers for the back end Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
