![]() | Home > Td5 > Transfer case front output shaft play. |
The clonk I would imagine is the drive flanges on the rear, mine made and awful clonk until I swapped them out for the once piece design.
T box, I'm sure someone who knows more than I will be along soon to help. Heres the shafts for the rear axle. https://lofclutches.com/shop/misc/defender...cba1185463 |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785 ![]() ![]() |
Small amount of radial play is normal as it is a ball bearing and not taper rollers.
Chamois Member Since: 24 Dec 2015 Location: Wanaka/Chamonix Posts: 114 ![]() ![]() |
Awesome thanks!
The output shaft only has a small amount of play, guess I’ll keep an eye on it. Found that the rear prop was loose at the same time so tightened the 4 nuts. Phew!! I’ll take a look at the flanges, thanks heaps!! Winter's here, thanks goodness! |
