Home > Td5 > Transfer case front output shaft play.
Chamois
2002 Defender 110 Td5 CSW Zambezi Silver
Hey everyone,
Just found that I seem to have a bit of play in the front Transfer case output bearing.
Does anyone know if this is normal??
Car is a 2001 TD5 CSW
Also getting a bit of a clonk whilst doing parking manoeuvres, any ideas what that might be?
Thanks heaps from down under. Winter's here, thanks goodness!
Post #951160 30th Apr 2022 11:47pm
kenzle8a
The clonk I would imagine is the drive flanges on the rear, mine made and awful clonk until I swapped them out for the once piece design.
T box, I'm sure someone who knows more than I will be along soon to help.
Heres the shafts for the rear axle.
https://lofclutches.com/shop/misc/defender...cba1185463
Post #951182 1st May 2022 10:09am
Retroanaconda
Small amount of radial play is normal as it is a ball bearing and not taper rollers.
Post #951195 1st May 2022 11:14am
Chamois
Awesome thanks!
The output shaft only has a small amount of play, guess I’ll keep an eye on it. Found that the rear prop was loose at the same time so tightened the 4 nuts. Phew!!
I’ll take a look at the flanges, thanks heaps!! Winter's here, thanks goodness!
Post #951201 1st May 2022 11:51am
