![]() | Home > Technical > Propshaft end |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 1003 ![]() ![]() |
After my prop dismantled itself yesterday I am a little nervous about reusing the sliding spline end. It clattered around on the road for a while before I could stop and remove it. My worry is that I buy a new flange, fit a new UJ and then this bit fails.
![]() Click image to enlarge Rest of the prop is sound so seems a bit of a waste to buy a while new one. ![]() Click image to enlarge ![]() Click image to enlarge The only ones I could find were a Bearmach one https://www.bearmach.com/product/propshaft...gLPU_D_BwE Or one from John craddock : https://www.johncraddockltd.co.uk/262468-g...mm-uj.html Would these suit? Not sure of all splines would be the same. Any other suggestions for a source? Thanks. |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 366 ![]() ![]() ![]() |
If it fits snugly on the splines I would crack test it and replace the universal.
It should be 100% then. |
Brand new UJ, greased up and everything
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2378 ![]() ![]() ![]() |
Crikey ! Circlips fail ? The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey |
Not much of it left to diagnose
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
If you can do without it for a few days send it to a prop shaft specialist, such as Bailey Morris who will check it, fit new universal joints, and then balance it. Good as new, if not better than many that you can buy.
