Home > Technical > Propshaft end
bodstruck
Propshaft end
After my prop dismantled itself yesterday I am a little nervous about reusing the sliding spline end. It clattered around on the road for a while before I could stop and remove it. My worry is that I buy a new flange, fit a new UJ and then this bit fails.
Rest of the prop is sound so seems a bit of a waste to buy a while new one.
The only ones I could find were a Bearmach one https://www.bearmach.com/product/propshaft...gLPU_D_BwE
Or one from John craddock : https://www.johncraddockltd.co.uk/262468-g...mm-uj.html
Would these suit? Not sure of all splines would be the same. Any other suggestions for a source?
Thanks.
Post #949731 18th Apr 2022 12:46pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
If it fits snugly on the splines I would crack test it and replace the universal.
It should be 100% then.
Post #949734 18th Apr 2022 1:20pm
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
A little late changing the UJ ? 😁
Post #949738 18th Apr 2022 2:24pm
bodstruck
Brand new UJ, greased up and everything Confused
Post #949739 18th Apr 2022 2:34pm
Mo Murphy
Crikey ! Circlips fail ? The Land Rover 90 - Many are called, few are chosen.
Post #949764 18th Apr 2022 5:54pm
bodstruck
Not much of it left to diagnose Smile could well have been a circlip failure. I will double double check them next time around.
Post #949770 18th Apr 2022 6:23pm
landy andy
If you can do without it for a few days send it to a prop shaft specialist, such as Bailey Morris who will check it, fit new universal joints, and then balance it. Good as new, if not better than many that you can buy.
Post #949792 18th Apr 2022 8:15pm
