Home > Puma (Tdci) > Three versions of the Alarm unit ?
Page 2 of 2 <12
Ianh
Correct. From what I’ve read The green AS10 alarm module is ok in all these respects, it’s the Replacement ALM units that have these issues.
Post #948467 7th Apr 2022 1:06pm
Mine has survived many years with LED interior lights.
Post #948473 7th Apr 2022 1:23pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Where did you read about the DH‘s brown out issue? I thought they fixed that with this update?
Also brown out and possible LED problems would be technically unrelated so one cant infer one from the other.
Post #948496 7th Apr 2022 4:56pm
macfrank
Embarassed just read the m1n1 link I posted a year ago. They seem to say both CH and DH are affected? Or is it mine or his English?
If so, why did we think DH were ok?? Neutral
Post #948498 7th Apr 2022 5:00pm
Ianh
I was about to say it was from re reading the link you provided, and I’m trying to remember if in the remotekey link it made me think DH units were ok, but re reading that it infers both are impacted.
Ps. I raised the led issue as a caution from the remotekey link, right at the bottom, and again no distinction between CH and DH units so wise to confirm with them if its just CH or both. No info on there as to if it’s connected to the brownout, just states they have had issues
Post #948521 7th Apr 2022 6:37pm
macfrank
Sad Thanks for raising that again.
re LEDs I meant Race.Its statement "does not suffer from these brown outs if the LED bulbs are used".
anyway, remotekey says "A problem with Defender 2012 onwards with the black unit fitted is they don’t function with LED interior lighting, we have had problems with the interior light circuit failing when LED’s are used."
I read that as not the whole unit burns to ashes but "just" the automatic light on/off dim feature. Well, I could live without that Confused Not using it anyway Laughing
Post #948538 7th Apr 2022 8:17pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Did not want to alarm, at present I have a as10 but don’t have led lights inside, so was more a confirmation that the as10 don’t suffer issues associated with others. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #948542 7th Apr 2022 8:40pm
110 Iain
United Kingdom 2008 Defender 110 Puma 2.4 USW Chawton White
Poverty spec
So I have a 2008 110 hardtop basic spec no key fobs abs tc basicly nothing but do have green 10as under dash so question what is it actually doing? On this spec asking because suffered a lot of starting issues recently Endeavour To Persevere
Post #948812 9th Apr 2022 8:26pm
Race.it
It’s doing your immobilized function, Basic as10 without the central locking relay inside Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #948814 9th Apr 2022 8:37pm
110 Iain
Thanks for reply wasn't even aware I had immobiliser function not sure how it works and what it actually immobilisers will need to try get more info incase it has been causing my erratic starting issues Endeavour To Persevere
Post #948818 9th Apr 2022 8:48pm
Ianh
Just responded in your original topic on your issue. https://www.defender2.net/forum/topic82977.html
Post #948837 10th Apr 2022 12:13am
Page 2 of 2 <12
