![]() | Home > Puma (Tdci) > Starting issues the saga continues |
| 110 Iain Member Since: 11 Nov 2019 Location: Scotland Posts: 93
So in trying to sort erratic starting issues have so far replaced earth cables new battery new ignition switch and finally new starter last week seemed fine after new starter started first turn for a full week but today went to start and just click click click checked. Battery OK is it possible I've got duff starter with bad solenoid. Or maybe I not tightened cables on starter enough. Losing the will now been trying to get reliable start for a year now. Any thoughts? Endeavour To Persevere
Update. Just got in from work and tried starting she fired straight up so sill got an erratic issue so to recap she has been poor at starting of and on for a year then wouldn't start at all dead so replaced initio switch no difference so new starter seemed sorted now erratic starter though brand new. Losing faith keep having to get lift to work when she fails Endeavour To Persevere
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18037
Disable the passive immobilizer and see if that changes anything.
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813
Stick a new battery in the handset and do the learning procedure that is in the handbook. It will be a cheap fix if it works. 1982 88" 2.25 diesel
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2541
110 Iain have a read of this https://www.defender2.net/forum/topic47486...p;start=90 , worth reading the whole topic, but page 7 , at the bottom, post from Martin explains a possible cause and solution, plus a way to test if that is the issue before cutting and joining wires or getting the instrument pack repaired.
| Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970
My passive immobiliser occasionally catches me out on my Puma, how do you disable it? Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
With a tool such as Nanocom.
110 Iain. Did you resolve the issue ?
