![]() | Home > Maintenance & Modifications > One piece half shafts, Britpart or LOF Clutches? |
| Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434
I am pretty sure both sellers are sourcing the part from the same manufacturer, simply because there cannot be many manufacturers of such an obscure part. That said, I have the ones from lof and have no complaints. Roaming around π³π΄π¨π
| jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 378
I recently put bearbach ones in mine. I assumed they're probably the same as the britpart ones, and I was placing an order from bearmach, so just added them on.
No issues at all so far (6 months and about 6k miles on them). A great improvement over the worn pieces I took off. |
| o4dn Member Since: 08 Jan 2010 Location: South West Posts: 588
Humm, Bearmach doesn't seem to list any compatible with the Puma Defender, which reference did you order? βA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, [β¦] it's up to you to do justice to your Land Rover!β - Land Rover Driving Technique.
-- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986
LOF is using same source as Britpart. I got mine from LOF as not much more and happy to support his business and get better customer service.
| Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727
I went with LOF for the same reasons as Landy Andy, plus the fact that LOF could do next-day delivery over a bank holiday weekend. My only complaint is that the flanges are not coated with anything and turned orange in the rain pretty quick, I'd recommend a quick coat of paint on them before installing
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
| Mother superior Member Since: 05 Aug 2013 Location: Surrey Posts: 506
Yeah, I went with LOF for the above reasons, it's always great to deal with Luke. Oh woe, oh woe
My crusty old landrover, It will not go. |
Right, but LOF is a tad more expensive and being oversees, next-day delivery won't apply. Besides, LOF doesn't seem to offer Paypal, which is a plus for me.
I have read https://www.defender2.net/forum/topic60317.html but I am still confused as to the right references to order for a 90 from 2009β¦ Would LR072976 and LR072977 fit? βA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, [β¦] it's up to you to do justice to your Land Rover!β - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" Last edited by o4dn on 15th Mar 2022 2:12pm. Edited 2 times in total |
| Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 406
I fitted Britpart one piece shafts to my 2015 90 about 25k miles ago and have had no issues. About Β£120 at the time delivered. I painted the flanges first as indeed they will rust.
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3747
Britpart for me. Done about 15k miles on them with no issues.
| kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074
I've got the Britpart ones, do paint them as the flanges do rust. However I've been very happy with mine.
I've just dug out my invoice: They were listed as FTC3271 left axle shaft FTC3270 Right axle shaft and also BR 3605 - Axle Shaft Gasket (2 of these) hope that helps |
Ah thanks! I wasn't sure about FTC3270 + FTC3271 but they are now out of stock at Bearmach apparently.
Meanwhile, Paddockspares confirmed that LR072976 and LR072977 where listed as compatible for my VIN, so I just ordered from them⦠Thanks everyone for the valuable advice on this forum, as usual! -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
