![]() | Home > Maintenance & Modifications > One piece half shafts, Britpart or LOF Clutches? |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
I am pretty sure both sellers are sourcing the part from the same manufacturer, simply because there cannot be many manufacturers of such an obscure part. That said, I have the ones from lof and have no complaints. Roaming around π³π΄π¨π
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 378 ![]() ![]() ![]() |
I recently put bearbach ones in mine. I assumed they're probably the same as the britpart ones, and I was placing an order from bearmach, so just added them on.
No issues at all so far (6 months and about 6k miles on them). A great improvement over the worn pieces I took off. |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 588 ![]() ![]() ![]() |
Humm, Bearmach doesn't seem to list any compatible with the Puma Defender, which reference did you order? βA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, [β¦] it's up to you to do justice to your Land Rover!β - Land Rover Driving Technique.
-- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5975 ![]() ![]() |
LOF is using same source as Britpart. I got mine from LOF as not much more and happy to support his business and get better customer service.
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727 ![]() ![]() ![]() |
I went with LOF for the same reasons as Landy Andy, plus the fact that LOF could do next-day delivery over a bank holiday weekend. My only complaint is that the flanges are not coated with anything and turned orange in the rain pretty quick, I'd recommend a quick coat of paint on them before installing
![]() 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
Mother superior Member Since: 05 Aug 2013 Location: Surrey Posts: 506 ![]() ![]() |
Yeah, I went with LOF for the above reasons, it's always great to deal with Luke. Oh woe, oh woe
My crusty old landrover, It will not go. |
Right, but LOF is a tad more expensive and being oversees, next-day delivery won't apply. Besides, LOF doesn't seem to offer Paypal, which is a plus for me.
I have read https://www.defender2.net/forum/topic60317.html but I am still confused as to the right references to order for a 90 from 2009β¦ Would LR072976 and LR072977 fit? βA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, [β¦] it's up to you to do justice to your Land Rover!β - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" Last edited by o4dn on 15th Mar 2022 2:12pm. Edited 2 times in total |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 401 ![]() ![]() ![]() |
I fitted Britpart one piece shafts to my 2015 90 about 25k miles ago and have had no issues. About Β£120 at the time delivered. I painted the flanges first as indeed they will rust.
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3726 ![]() ![]() ![]() |
Britpart for me. Done about 15k miles on them with no issues.
I've got the Britpart ones, do paint them as the flanges do rust. However I've been very happy with mine.
I've just dug out my invoice: They were listed as FTC3271 left axle shaft FTC3270 Right axle shaft and also BR 3605 - Axle Shaft Gasket (2 of these) hope that helps |
Ah thanks! I wasn't sure about FTC3270 + FTC3271 but they are now out of stock at Bearmach apparently.
Meanwhile, Paddockspares confirmed that LR072976 and LR072977 where listed as compatible for my VIN, so I just ordered from them⦠Thanks everyone for the valuable advice on this forum, as usual! ![]() -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
