Home > V8 > 3UZ-FE conversion
Page 4 of 9 <123456789>
Timbo
England 2008 Defender 110 V8 Petrol USW Tonga Green
Hi Dinnu, I see what you're saying. If it's an issue I'll put bigger bump stops on thank you for drawing it to my attention though Thumbs Up
Post #943375 21st Feb 2022 10:02pm
Timbo
Some stainless steel plate I had knocking about Very Happy
BMW linkage bar fitted. Need to work out length
Plate cut and brackets welded on to connect to gearbox
Turret off MT82 Gearbox will bolt to this plate and hopefully I'll be able to select some gears.
Post #944662 4th Mar 2022 11:05pm
LJMARSDEN
United Kingdom 2006 Defender 90 Td5 HT Java Black
Jeez, thats a lot of work Whistle Luke Marsden
06 V8 1UZFE Defender 90
Instagram: https://www.instagram.com/defender__v8/
Post #944663 4th Mar 2022 11:08pm
Timbo
You aint kiddin' Laughing I spent a while making all this stuff work and today I tinkered a lot to make it select gears. The biggest drawback with this set up is that it has to be assembled before the engine is fitted then firkled in Confused I'm not looking forward to that. The loom is in the hands of phoenix at the moment so hopefully it will be running soon Whistle Let's see where you're at Whistle Rolling with laughter
Post #944667 4th Mar 2022 11:26pm
LJMARSDEN
Yeah your hands are certainly full at the minute. but Tim, I think you'll be surprised with the progress I'll be making in the next two weeks Whistle Thumbs Up Luke Marsden
Post #944671 5th Mar 2022 1:26am
Timbo
It just might work Wink
It now sits at the same height as before so should come through tunnel in right place but it wont go in through gap attatched to engine so will need to be retro fitted. This may mean I need to cut a section of tunnel out to assemble in situ Big Cry
Post #944748 5th Mar 2022 10:06pm
Timbo
Fuel lines and fliter put in
Lexus pedal fitted for fly by wire
Post #944861 6th Mar 2022 10:13pm
Timbo
I'm not going to lie I'm getting excited now Laughing
Post #945591 12th Mar 2022 11:00pm
LJMARSDEN
You’re making me look lazy with all this progress Rolling with laughter
Chris seriously knows his stuff.
Can’t wait to see and hear what it’s like in your 110 Tim Thumbs Up
(Will sound better in a 90 tho) Rolling with laughter Luke Marsden
Post #945596 13th Mar 2022 1:09am
Timbo
I've spoken to him via messenger a few times and he is very helpful. The only drawback at the moment is the gizmo to talk to my instrument cluster is due to come from russia Shocked . I have to start thinking about exhaust now ( To make sure it's louder than yours Laughing )
There's also the issue still of heater box and airbox to sort. I'm pretty sure there'll be other stuff to overcome too. I'm enjoying having to think about each step but don't try and think too far ahead as it will depress you but planning ahead is important too. Radiator is something I'm going to have to make a move on soon too. Blimey I'm depressing myself going over my to do list Rolling with laughter
Post #945699 13th Mar 2022 10:01pm
LJMARSDEN
I agree 100% Timbo, best is to tackle it mentally bit by bit. Like tomorrow I plan on throwing the cams in and the new sump on. So anything after that will be a bonus.
your exhaust simply will not be louder... Rolling with laughter
(I cannot be sure since I haven't really thought about it yet... or have I?)
I measured the mounts from the TD5 chassis to the distance between the mounts on the 1UZ, I reckon I might be getting lucky and so the mounts I need to make will not be so much work. Bow down
I still havent thought ahead about anythign really other than the electronics, as that "stuff" Scares me Rolling with laughter Luke Marsden
Post #945705 13th Mar 2022 10:57pm
Timbo
Connecting main harness
Connecting sub harness. Chris from Phoenix Engine Management has proved to be a really helpful guy so far. Thumbs Up
Post #946222 18th Mar 2022 10:30pm
LJMARSDEN
Great stuff, you're really pulling ahead of me at the minute. Bow down
that oil cap spout looks massive, is that the standard 3UZ one? Rolling with laughter Luke Marsden
Post #946225 18th Mar 2022 11:02pm
Timbo
Yes
Post #946228 18th Mar 2022 11:08pm
Timbo
Hoping engine goes in with Gbox and Gearlever attatched
It does! And it's in the right place!
Post #947147 26th Mar 2022 10:30pm
