![]() | Home > My Defender > 1988 Shire Blue Landrover 90 Restoration |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3786
Looks great as always. Keep the updates coming!
| Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 435
Really enjoying this build 👍🏼 Roaming around 🇳🇴🇨🇭
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3651
And top side of the seatbox.
Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Engine out again, due to an oil drip after starting the engine to test.
Click image to enlarge What I noticed is that the rear main bearing cap is 0.15mm further in from the engine block. Very strange, I have not checked it before disassembly. Those T seals were very difficult to install, and I do not have the special wedged to guide them in, but I trust that the main bearing cap is installed correctly. Crank still turned freely when the main bearing cap bolts where torqued 🤷 So most likely I did not apply enough sealant to cater for that 0.15mm gap. Fingers crossed, it is ok now. Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Seat box is in, at least kind of. Then realised that I forgot to re glue the original insulation foam back
Between the battery box and seatbox I applied double sided tape. Acts as a barrier, although there is also good layers of paint and galvanizing on the battery box, but helps to seal too. Quite sticky stuff I use, so need to wrestle a bit to align all the rivet holes. Sorry, bit of a dark photo. Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11094
Fingers crossed for you, hoping that you have fixed the oil drip and the seat box is looking good in it's place
| jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 408
Noticed your image of the engine out again, Have you considered fitting an intercooler to the engine? I know it isn’t an original item and you’re definitely doing a good job of restoring your vehicle, but it probably would be a worthwhile addition to try to increase the engine life especially given the bad reputation the 2.5td has.
Thank you Clayton.
Next: Click image to enlarge Few rust pin holes in the blower scroll to fix. Taken apart because the flaps lost the foam, and the steel to steel rattle used to drive me crazy. In fact the heater setting was never set on all cold or all hot for that reason. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Will be great when the jigsaw is all back together, as your doing it, it will be better than new
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
So many pieces!! Once the oil leak is fixed you must feel like you're on the home straight? James
Hi Jimbo, I have been toying with that idea since I removed and opened the old engine.. so that is quite some time now What I plan to fit though is an EGT monitor. It will be barely visible, as I can control the amount of fuel and hence the temperature with my right foot. The problem is however I do not know what is a safe EGT value for this engine. I have also not used any components of my earlier engine, original engine number was 19J11xx. All components are from a newer 19J with engine number 19J31xx. Some date codes that I could find is that it was build around October 1989. That would give me one of the latest 19J engines, which were improved . I do not know if the head/pistons (weak points) on this engine were the original ones, but can state that when I opened it, the head was in perfect condition, and only very minor cracking on 2 pistons. The only history that I know of this engine is that it powered a 90 with a heavy trailer from the UK to Malta My previous engine had a very hard life. I regularly towed heavy trailers, and I did become a bit careless with the cooling system. Probably not even a tdi would have survived my abuse 2012 90 CSW, 2.2TDCI, Santorini Black |
Home run 2012 90 CSW, 2.2TDCI, Santorini Black |
I'm very much enjoying the resto journey too, so no hurry! One part at a time.... James
Back to the engine durability, I wonder if it would have been a good idea if I simply got 12J (the normally aspirated) pistons, and shaved of a bit of their tops to reduce the CR.
Looks like every 0.25mm removed from the piston will reduce the CR by 1. 12J and 19J runs with CR of 21:1. For comparison, the Tdi run at 19:1, TD5 run at 19.5:1, the 2.4 run at 17.5:1 and the 2.2 run at 15.6:1 Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| All times are GMT |
