Home > Faults & Fixes (L663) > Gearbox Repair on Brand New Defender
Nuclear Nick
Delivered on 25 December......
Into workshop for repair due to cracking noise from the gearbox:
Back 'off road' following successful repair and test:
Post #938832 22nd Jan 2022 3:10pm
gilarion
I can recomend this mechanic for all gearbox related items.
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #938834 22nd Jan 2022 3:29pm
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Re: Gearbox Repair on Brand New Defender
Did you have to wait long for parts? Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #938846 22nd Jan 2022 4:34pm
Balvaig
Probably water ingress Very Happy
Post #938847 22nd Jan 2022 4:38pm
Nuclear Nick
No. It was an assembly fault due to an incompetent poorly trained and inexperienced worker. The fault was not found during assembly resulting in extensive disassembly to identify and rectify the fault. It turned out to be a gear wheel loose in the ‘box which could be returned to its rightful place with some difficulty due to tight access, so no new parts were required. The worker has been sent for further training.
Post #938849 22nd Jan 2022 4:43pm
Muddybigdog
What loner car did they offer you? Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #938853 22nd Jan 2022 4:57pm
whiterdesign
Probably this one
 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
Post #938878 22nd Jan 2022 7:26pm
stng110
Australia
Well, mine has the same problem. Typical JLR subcontractor quality. But now my assembler is refusing to pull the car apart. Every time I mention it, he just bursts into tears. I’m not getting much sympathy from my significant other.
I guess it’s just a garage queen, so who’d ares if it doesn’t work. Right?
Post #940068 29th Jan 2022 7:46pm
Nuclear Nick
Nooooo, it needs to be purfect! I fixed mine with the help of some really good You Tube vids. Apparently the usual culprit is the CV joints in the two drive couplings to the gearbox and transfer box. It’s not made clear in the instructions but the joints need to be all aligned the same initially. In my case I think I dislodged the gear wheel when I was decoupling the drive shafts. All running silky smooth now.
Post #940100 29th Jan 2022 10:51pm
Leeds Utd
Germany
Lets hope it brings as much fun as the real thing ! Bow down Thumbs Up Wink Very Happy
Post #942915 18th Feb 2022 9:46am
Smyles_
Denmark
Interestingly there was actually an error in the manual for the construction of the drive line in regards to u-joint alignment.
 Stuart
Cummins 130 Build Thread
Instagram
58 130 Double Cab HCPU - Cairns Blue
04 110 Double Cab - Black (gone)
07 Audi RS4 Avant - Silver
Post #942920 18th Feb 2022 10:20am
Nuclear Nick
Yes, that was the problem I had. I found a similar video so I was able to sort it but the video you posted is much better in explaining the problem and the solution. While the instructions supplied with the kit are very good there are also some very good videos out there too. Probably some of those guys need to get out more! Laughing
Post #942929 18th Feb 2022 11:15am
X4SKP
Interesting... and thanks... Thumbs Up
Just about at that stage... so will align UJ's as suggested...
Let's face it LEGO were trying to build a Model with Defender DNA... Shocked SKIP
Post #942931 18th Feb 2022 11:23am
Nuclear Nick
Can I suggest, with the benefit of hindsight, that you fit the wheels somewhere around stage 365, before fitting seats and bodywork, and try out the transmission in all its modes? This might avoid having to do a lot of dismantling to get back into the drive train to sort out any issues.
But then you may already be planning to do this....... Smile
Post #943031 19th Feb 2022 11:33am
