![]() | Home > My Defender > 200Tdi 110 |
I had that Southdown setup on the rear of a Discovery many years ago. An excellent bit of kit and a real shame that they went out of production. Darren
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 412 ![]() ![]() ![]() |
How did you rate the MT/R's for niose on road?
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 1005 ![]() ![]() |
Well, it turns out that Warn 9.5cti winches don't seem to fit tubular bumpers. That is a shame.
Just ordered a new Winchmax one instead. Should do just fine for what I need ![]() |
New (to me) winch bumper and steering guard fitted over the weekend. Was certainly a trickier job than it should have been, nothing seemed to line up. Didn't want to drill or cut the galvanised chassis so a few modifications were required to the guard and bumper mounts. Got there in the end though. I also have an A-bar to go on to mount some lights to but will reserve judgement on those until after my trip to the lakes on the 17th I think.
![]() Click image to enlarge Good job I didn't get one that needed a body cut. When I took the grill off I found that the intercooler was full height and the would have been no room to tuck a winch in there. Winch is due to arrive tomorrow and that will hopefully be a straightforward fit. |
Winch is on after a fair bit of jiggery pokery. Installation was simple enough but the wiring was a pain. A straightforward task but beset with problems, all of which were overcome so all good
![]() While I was installing I also noticed that the intercooler had been place touching the front panel and over time it has actually cut into the intercooler. Luckily not penetrated but a close thing. ![]() Click image to enlarge ![]() Click image to enlarge Disappointingly I think the southown guard might not be possible. The rear crossmember does not have any captive nuts on the underside. The existing step is fitted with nuts and bolts but there will be no way of getting a spanner in past the guard to hold the nuts. I'll do some more head-scratching before I give up but will be a job for another day. Last few jobs before heading off the the lakes next week include securing the headlining as it is not actually fixed to the roof ribs, fit the winch rope, check the oil and then go. Not really looking forward to the 300 mile journey up but the laning should be fun so looking forward to that. |
![]() Click image to enlarge Made use of a tank track marker and a perfectly smooth sloping surface just around the corner from my house to tension the new winch rope as I spooled it ![]() ![]() Click image to enlarge |
Whilst taking it for a teat drive after adjusting the steering stops I noticed the fan blower had packed up again and the screen was misting up. Quick search on here and Google led me to suspect the drain valve on the heater intake was blocked so nipped out at lunchtime to check it out
For some inexplicable reason the wing top chequer plate sits over very vent cover! I had to drill out the rivets and remove it before I could get to intake Gubbins. ![]() Click image to enlarge There was quite a bit of water in there and loads of junk blocking the drain. The water had also filled the fan housing. I cleared the drain and cleaned up around it. As I was heading off to the lakes in the afternoon I didn't really want to take off the heater to empty it so I managed to cobble together a solution using a syringe I had lying around for some reason and some heat shrink tube which I used to pass though the blades of the fan and gradually suck out the water. ![]() Click image to enlarge It took a while but I got there in the end. Freed up the fan, replaced the fuse and job done. 6 gour drive this afternoon and no problems ![]() Well, I say jo problems but I think the clutch isbon the way out and I fear it may not last the next 4 days if laning ![]() |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11062 ![]() ![]() |
Got my fingers crossed for you with the clutch lasting for your until you get home
It made it
![]() 600 mile round trip and another 500 ish across the lakes, dales and moors. Great trip. ![]() Click image to enlarge |
Good news and a nice pic
![]() I can un cross my fingers now ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Now that the td5 110 has gone I can focus on sprucing this one up a bit. I think it is worth investing in
![]() First job when back from the lakes was a new clutch. Probably not needed but the cost was not much greater so had a LOF powerspec one fitted as well as a new downpipe while the crossmember was off. The 33" BFGs were good but a bit wide for my taste. And they looked well on the grey td5 so they went with that one. I sold the Wolf / Goodyear combo and bought a new set of Cooper STT pro in 235/85/16 which I had fitted to some spare wolf copy rims I had in the garage. I like these. Good price and performed well on a trip to Wales just after Christmas. ![]() Click image to enlarge ![]() Click image to enlarge I went on a mini spending spree the other day in preparation for the work ahead. New door seals, bulkhead to screen seal, windscreen seal, wiper blades, gear knobs and vent seals. Also a new water pump as I seem to have a bit of play in mine. Some new pads for the X-Eng disc handbrake. And finally some new seat base foam for the puma seats. A couple of the doors are a bit rubbish so after searching around for good second hand and procrastinating I went for it and ordered four new galvanised doors from SP4x4. Expecting them to arrive any day now. Plans are: Strip out the rear and do away with the hatch on the side. Hatch, dog guard and internal water tank will be for sale soon) Fit the doors and new seals, using the existing windows, locks etc. Replace rear seats with some from a Renault Grand Scenic. I know you can just bolt them onto the existing frames but I would like to make them removable as they are in the car and then have the middle one interchangeable with either a storage box or my engel fridge Strip and recover the headlining, insulating the roof while I am at it New rock sliders with tree bars (like having them as a step) Swingaway wheel carrier Paint job. Although I am undecided on colour at the moment. A colour change will not be too tricky as the replacement bulkhead is painted black inside the engine bay and the inside of the bulkhead is still bare galv. I quite like the red although it has 2 different shades on it at the moment - you can see the original colour peeking through on the front wing ![]() Click image to enlarge And finally the bit I am really undecided about. I would like to fit a full external roll cage but that is one of those jobs that there is not much going back from once you cut some sizable holes in the sides. Need to contemplate that one some more. But I think I have enough to occupy me for now. |
Doors arrived slightly quicker than anticipated
Great service from them
Erm, slight issue on the road today. Rear prop decided to dismantle itself
![]() ![]() Click image to enlarge ![]() Click image to enlarge The UJ was new, only been in for short while. Well greased before use. Managed to reverse back gently to a layby and luckily had two 14mm spanners in the back so removed the prop. Happen to have a spare at home so will fit that at some point. Bit of a surprise when it went. |
