Home > Tdi > Cambelt Pulley System issues??
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Hi folk ... Still working on and learning about my newly acquired 1994 Defender 90 TDi300.
Today I was flicking through a book called "You & your Land Rover Ninety, One Ten and Defender" by Martin Hodder and I came across this comment on page 115 (See top right of picture):
So what's is the modification? ... and how do I know if I'm pre mod of post mod please??
Cambelt last changed in 2011 at 126,000 miles ... now 156K
Thanks all
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #937720 14th Jan 2022 5:10pm
ickle
IIRC the bottom pulley used to fail / fall apart with belt shredding results - again from memory there was a bottom pulley supplied with the better cam belt kits.
Hth Keith
Post #937733 14th Jan 2022 6:47pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
If you do an Internet search you should find good information.
I think basically one of the pulleys has shoulders on. They changed which pulley as the earlier setup caused wear on the belt and thus premature failure.
Also worth noting is the later pulley has two types. One version has presses steel shoulders spotwelded to it which I believe can fail. The later type has machined shoulders, so don't fail.
My computer is currently not working so I don't have the part numbers. But I am sure you will be able to find them easy enough. If you do a search on here I would think you will find a thread about it.
Basically, as soon as you do a cam belt change, make sure you put the later gear on.
Also be aware that if you do get a cambelt kit it won't have everything you will need for doing the job!
Mick
Post #937737 14th Jan 2022 6:59pm
Dinnu
https://www.lrworkshop.com/blog/300tdi-replace-timing-belt 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #937742 14th Jan 2022 7:10pm
Cubflyer
Ickle, Mossberg and Dinnu - Thank you so VERY MUCH for the prompt and excellent answers! ... REALLY appreciated.
All I've got to do is find out what pulley is fitted!
Although the last cambelt was changed ten years ago the Defender has only done 30K, what's your thoughts / advice?
Gut feeling are that because its been 10 years, change it (and get the pulley checked) but of course its £££ and I've got the beast booked in for new sills to be fitted next month £££
As always your advise/comments are greatly welcomed.
Thank you and have a good weekend!
Post #937759 14th Jan 2022 8:50pm
Mossberg
Get the cambelt done - definitely. I think the maximum time between changes is 7 years.
Post #937761 14th Jan 2022 8:53pm
Oldowner
If not already fitted you also need to change the injector pump bracket for the revised one that prevents the timing cover moving out of position. Probably only a quarter of the 20+ 300tdi’s that I have owned over the years have had the revised bracket fitted.
You may find that once the revised bracket is fitted, you might have to renew the injector pump head O ring as the reposition of the fuel pump in the correct place by the bracket can cause it to leak if the timing cover has previously been sat out of position slightly.
There was supposed to be a yellow square painted on timing cover if all modifications were done but again in over 20 300tdi’s I have never seen a yellow square!
Whoever fits the kit also needs a MHH Torqueleader to do it properly. Many so called specialists
don’t have one.
Post #937768 14th Jan 2022 10:11pm
htb2
Wales
Old, do you have a picture of the bracket, so I can check if its fitted on mine.
Thanks
Post #937771 14th Jan 2022 10:13pm
Oldowner
It is err6835
Post #937772 14th Jan 2022 10:16pm
Cubflyer
don’t have one.
Thanks Oldowner - appreciated as always.
Post #937784 14th Jan 2022 11:23pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
An alternative POV to the modification bracket saga is that if your vehicle has got to this point without shedding a belt and the belts are coming off in reasonable condition at replacement time then your engine probably doesn't require the mod.
Post #937807 15th Jan 2022 9:28am
Cubflyer
Hi OS ... Certainly your POV is well worth considering: Appreciate your input Thumbs Up
Post #937863 15th Jan 2022 6:50pm
ickle
The other view is a broken Cambelt will always happen at the most inconvenient time and then the cost will be eye watering.......
Post #937883 15th Jan 2022 8:56pm
Cubflyer
Well, after this discussion I've just got my Defender back after having the Cam belt changed and three pulleys.
The workshop looked at getting a genuine fuel pump bracket (over £100) too, but after some thought got an "After market" bracket at half the cost. Sadly upon arrival one of the holes was over 5mm out and was not worth fitting. Given the condition of the original cam belt (10 years old) the decision was to use / keep the original one.
Now much happier and job done knowing I've got the correct pulleys and a new belt Very Happy
Another fault fixed Thumbs Up
Thanks for all your inputs 2010 Defender 90 300Tdi CW (White/1994)
Post #941869 9th Feb 2022 11:13pm
Jeebs
United Kingdom 1995 Defender 90 300 Tdi HT Barolo Black
Oldowner wrote:
It is err6835
Bit of a topic resurrection, however currently in the process of getting my 300tdi back on the road after a messy breakup. Cambelt snapped while trying to get it away from the ex so she couldn’t set it on fire Laughing
I’ve got the improved kit and ordered a bracket, what else is required? I did the belt about 6k ago but it snapped very prematurely, so my guess is I missed something last time.
Post #952854 18th May 2022 10:48am
