![]() | Home > Puma (Tdci) > Beep/ ding when turned off |
| Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306
Central locking fault?
One of the door lock actuators could be on its way out or wiring. |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052
You get a noise from the egr valve doing its then when turning engine off. I canβt think of anything else.
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3644
The only time I get a beep / chime is when I am running low on fuel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031
I don't think that there's anything fitted as standard on a 2007 Puma which would do this, so I'd be looking for something aftermarket, possibly entertainment system or alarm.
The well-discussed EGR noise (search the forum) is hard to mistake for a beep or ding. |
| Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434
Mine will make a bong sound if I turn off the ignition with the headlights lights on Roaming around π³π΄π¨π
| JPE Member Since: 19 Nov 2018 Location: South West England Posts: 347
I wish mine beeped when I leave the lights on!
I'm forever having to unlock it again to turn the lights off! |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363
Same. The only bong mine ever makes is low fuel > 110 XS Double Cab
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2534
Easy to fit one of these and you will have a buzzer to remind you when ignition off, lights on, and door open. https://www.carbuilder.com/uk/lights-left-...gLYFfD_BwE |
| matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120
Have a look at the link below. I fitted a relay and buzzer from an auction type site. Added a press switch from Halfords. Awesome cheap setup to gently remind me I have left the lights on!
https://www.12voltplanet.co.uk/relay-guide.html |
I find the fact the light switch is so near the ignition switch makes it know that the lights are on.
Haha. The lights are so poor you barely notice them as on!
Luckily the LED lights draw so little power that even after leaving on for 24 hour mine still started > 110 XS Double Cab
