Home > Puma (Tdci) > Beep/ ding when turned off
MSmith7069
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all,
Had some time off and tried to locate what it means. Sometimes when turning the car off I will get a long beep/ dog/ alarm sound inside the cab. Unsure why it does it as will be random as t when it does happen.
Any ideas what this could be
Post #934747 22nd Dec 2021 10:58pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Central locking fault?
One of the door lock actuators could be on its way out or wiring.
Post #934756 23rd Dec 2021 12:49am
landy andy
You get a noise from the egr valve doing its then when turning engine off. I can’t think of anything else.
Post #934766 23rd Dec 2021 8:10am
Dinnu
The only time I get a beep / chime is when I am running low on fuel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #934767 23rd Dec 2021 8:19am
I don't think that there's anything fitted as standard on a 2007 Puma which would do this, so I'd be looking for something aftermarket, possibly entertainment system or alarm.
The well-discussed EGR noise (search the forum) is hard to mistake for a beep or ding.
Post #934768 23rd Dec 2021 8:28am
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Mine will make a bong sound if I turn off the ignition with the headlights lights on Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #934776 23rd Dec 2021 9:53am
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
I wish mine beeped when I leave the lights on!
I'm forever having to unlock it again to turn the lights off!
Post #934789 23rd Dec 2021 11:33am
hank
Same. The only bong mine ever makes is low fuel > 110 XS Double Cab
Post #934790 23rd Dec 2021 11:37am
Ianh
Easy to fit one of these and you will have a buzzer to remind you when ignition off, lights on, and door open.
https://www.carbuilder.com/uk/lights-left-...gLYFfD_BwE
Post #934834 23rd Dec 2021 4:36pm
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
Have a look at the link below. I fitted a relay and buzzer from an auction type site. Added a press switch from Halfords. Awesome cheap setup to gently remind me I have left the lights on!
https://www.12voltplanet.co.uk/relay-guide.html
Post #934843 23rd Dec 2021 6:14pm
landy andy
I find the fact the light switch is so near the ignition switch makes it know that the lights are on.
Post #934859 23rd Dec 2021 8:43pm
matchap801
Haha. The lights are so poor you barely notice them as on!
Post #934894 24th Dec 2021 12:16am
hank
Luckily the LED lights draw so little power that even after leaving on for 24 hour mine still started > 110 XS Double Cab
Post #934912 24th Dec 2021 10:36am
