Home > Td5 > TD5 Heater Fan
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
TD5 Heater Fan
Help!
So the heater was working ok up until a few days ago, now nothing!
I have tried all the obvious stuff,
1. Checked fuse, think there is only one fuse? It's ok.
2. Checked that fan actually spins by sticking my hand into the fan from the wing! It's fine and spins freely.
3. Replaced the fan switch with a new genuine Land Rover one!
4. I get power at the fan switch, power on both green wires? Is that normal? Not sure how the switch works with a resistor?
Anyway flummoxed! The trip up to Aviemore last night was interesting in -1°!
Any help would be appreciate.
Thanks
Duncan
Post #933205 11th Dec 2021 5:37pm
dorsetsmith
heater switch first stage swathes ground with resister - stage two or flat out bypasses resister to the motor
check that you good ground the switch
black wire with black spade on the end and male spade lug on the switch lever
Post #933214 11th Dec 2021 6:34pm
htb2
Looks like an earth problem from the switch.
Post #933216 11th Dec 2021 6:39pm
Tank
Thank you, I'll have a look at that.
Electrics isn't my best out will see what I can do.
Duncan
Post #933218 11th Dec 2021 6:48pm
Tank
Can I ask if there is a difference between the two green wires? Do they need to go a certain way round?
Thanks
Duncan
Post #933269 12th Dec 2021 11:59am
dorsetsmith
plug is pin 1 GS - green -slat gray
2 GY - green -yellow
3 Black
and heater slide switch is
Post #933276 12th Dec 2021 1:08pm
Tank
Thank you
Post #933290 12th Dec 2021 4:15pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Great and detailed information as always Dorsetsmith Thumbs Up Thumbs Up Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #933333 12th Dec 2021 11:35pm
Tank
So Dorsetsmith, it appears I have more than just this issue now!
Driving home from a weekend in Aviemore last night and I had the heated front screen on, the lights and I was using the windscreen wipers. I noticed that if I had the front heated screen on, and the rear as well that every time I used the wipers the speedometer dropped and the needle pulsed or flicked in time with the wipers Rolling with laughter
Does this mean I have a major earth issue? How many earths does the TD5 have and where are they. I assume if one or all of them are corroded that this could cause not only the issue with the heater blower but also the other electrical gremlins I have discovered?
Dunk
Post #933450 13th Dec 2021 5:47pm
dorsetsmith
start with your battery neg follow onto the chasse and then on to transfer box over to driver side under nether chasse to body work strap and in engine bay just behind coolant expansion tank earthing header
good place start with
earth header C0289 K109 behind centre fascia (radio )
C0550 k108 engine bay just behind coolant expansion tank earthing header on the bulkhead
have check earthing from battery . run temp wire down from the heater switch to the battery neg and see if this helps with your earthing problem
under nether driver side chasse to bulkhead strap
Post #933460 13th Dec 2021 7:03pm
Tank
Thank you so much, really appreciated.
I had a lot of bulkhead work done with windscreen out and other bits off, wings etc etc. Maybe the earths havent been put back correctly.
Regards
Duncan
Post #933520 14th Dec 2021 11:04am
Tank
Hi Dorsetsmith
So gets even more interesting now as there is a smell of burning, so my son tells me. I can't smell it as I am getting over Covid and have no sense of taste or smell! Where is the earth strap behind the dashboard is it easy to find?
Dunk
Post #933731 15th Dec 2021 9:02pm
dorsetsmith
earth strap
Under nether vehicle on driver side between chasse to bulkhead
Post #933751 15th Dec 2021 10:06pm
Tank
OK
I'll get under the car at the weekend.
Could that be the issue?
Dunk
Post #933764 15th Dec 2021 10:30pm
dorsetsmith
Post #933768 15th Dec 2021 11:31pm
