![]() | Home > Td5 > TD5 Heater Fan |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 ![]() ![]() ![]() |
Hi Dorsetsmith
Thank you. Shame you are so far away! I could have got you to fix it ![]() |
Link 5 60 amps in the under seat fuse box is the supply to starter relay and ignition switch
Ah, well that works then as the car drives and starts fine, so its not that. Thanks that saved me the faff of taking the seat out to have a look (i have fancy seats
![]() Cheers Will keep trying! Cheers Duncan |
OK still no blower fan!
Is there a way of putting power to the fan via the connections in the engine bay to see if it will spin up? Cheers Dunk |
freddie206 Member Since: 18 Oct 2015 Location: Skipton Posts: 90 ![]() ![]() ![]() |
Hi Dunk,
I wanted to do the same thing a few years ago so I bought a Sealey PP1 Auto Probe. It’s ideal for powering up 12v components. Hope that helps Fred |
![]() at the plug purple and green wire needs to have 12 volts + to battery - with the ign switched to pos ii Green and slate gray wire and green and yellow are switched to ground i.e. battery - this cared out with heater speed control a Digital Multimeter so you can read dc voltage and Continuity and Resistance and Test wiring good tool |
