Home > Puma (Tdci) > Simple CTEK charger question.
Page 2 of 2 <12
Bear in mind that the standard lighter socket isn't live unless the ignition is switched on, so is no good for charging. Darren
Post #932677 6th Dec 2021 10:35pm
nitram17
Re: Simple CTEK charger question.
Julie wrote:
Pat wrote:
I'm sure I'm asking a laughable question, but Defender electrics frighten me.
CTEK sells adaptors for cigar lighters , too
I like that solution because I don't have to access the batteries, I can choose between board and service batterie and the charger is inside ...
I don't know about pree puma defenders but the puma cigarette lighter is not permanently live so requires the ignition to be on to charge! Unless you feed a permanent like to the socket its a non starter for me.
LRA Thumbs Up
Post #932687 7th Dec 2021 12:15am
X4SKP
I like that solution because I don't have to access the batteries...
As LRA + nitram17 say... 'we' are sure that your Puma Julie will not have a permanent live standard cigarette lighter (or cigar... Thumbs Up ) picking up on the rear permanent live and installing an additional socket/s could be the way to go...
https://www.defender2.net/forum/topic20319...anent+live SKIP
Post #932704 7th Dec 2021 10:50am
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
2x permanent live for the différent batteries in the front for charging and heavy consumers (cooling box)
& in the rear only permanent life from service battery (living comfy Smile
Post #932891 8th Dec 2021 8:57pm
TJ101
X4SKP wrote:
Hello Pat...(not a laughable question...)
2. I would also consider buying a CTEK Indicator Panel and wiring it up to the Battery Terminals and mounting the Connector 'receiver' somewhere 'logical', involves some hole cutting under or around the seat or with luck / adaption you could get this up to and within the Cubby Box. The Indicator Panel also has a simple traffic light battery status display.
Thumbs Up for CTEK (mines been faultless), good luck with yours.
Mine are all looked after via a Cetek, The 110, with one of the above in the MSS cubby box,, simple California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #932912 8th Dec 2021 11:33pm
Page 2 of 2 <12
