![]() | Home > Puma (Tdci) > Simple CTEK charger question. |
Bear in mind that the standard lighter socket isn't live unless the ignition is switched on, so is no good for charging. Darren
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
As LRA + nitram17 say... 'we' are sure that your Puma Julie will not have a permanent live standard cigarette lighter (or cigar... ![]() ![]() Click image to enlarge https://www.defender2.net/forum/topic20319...anent+live SKIP https://www.defender2.net/forum/topic83242.html |
Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589 ![]() ![]() ![]() |
2x permanent live for the différent batteries in the front for charging and heavy consumers (cooling box)
& in the rear only permanent life from service battery (living comfy ![]() |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Mine are all looked after via a Cetek, The 110, with one of the above in the MSS cubby box,, simple California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
