![]() | Home > Maintenance & Modifications > Wind deflectors |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2285 ![]() ![]() ![]() |
I have Climair ones on the 90 and find them quite useful only slight issue is they very slightly obscure your line of sight
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Climair, but i don’t bother with the clips… they sit fine without them and make the job fiddly. QRZ 2e0vpf
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 281 ![]() ![]() ![]() |
My wife has them fitted on her VW T6, like "90 Dreamer" above ... I find they can slighty obstruct your view and are held in place with metal clips ...
HTH 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
My T5 also has them but they were OE VW ones and don't have any unsightly clips.....
I’ve had the climair ones on for about a year, one of the best mods I’ve ever done, esp on hot wet days in the summer in a td5 with no ac they are brilliant
Her T6 clips are not visible, they fit into the recess channels of the window glass. 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2389 ![]() ![]() ![]() |
No clips on my climair ones, works fine. I'm not sure I'd trust stick on ones especially if you go laning.
As a matter of interest ... those of you that have them:
... Are yours tinted or clear?? 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
Tinted but i didn’t realise it until they arrived, I’d go for clear if i got another pair, it’s not bad but i couldn’t be bothered to send them back
Mine are clear.
pilsburypie Member Since: 19 Jul 2021 Location: Birmingham Posts: 176 ![]() ![]() ![]() |
Lots of replies all saying you have the Climair ones.
How far do they protrude from the outer door frame? My initial thoughts was I prefer the Britpart look. But Climair seem to be the firm favourite here |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
Tinted stick on’s
![]() Click image to enlarge Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 942 ![]() ![]() ![]() |
My Dad has the climair ones on his Discovery 2, they have been on for years, effective and a good fit no problems with them
kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232 ![]() ![]() ![]() |
Just put a question on about these wish I had asked people before trying but they where easy to fit. I have put Clim-air wind deflectors on I ordered and waited 6 weeks for Clim-air clear ones fitted them as the instructions said with a bit of washing up liquid but got a bit tight at the top but the window went up and down as they should for a week or so then the winder went free and then on closing the door the window fell down anyway I have taken them out as the window was tight at the top on the passenger side too I have put the window back on and added sealant to the two clips it sits in I do want to refit them as I like to unwind the window now and again without getting soaked any ideas on these being fitted without damaging the window. I did have the outside stick on type on the Puma and tinted but struggled to see out of the top of the passenger window due to the them being tinted and they don't do clear that is why I have gone with Clim-air. The only thing I can think why this happened is that the wind deflector gripped the window and when I wound down the window the grip has dislodged the 2 clips under the door panel the window sits on. Thanks |
