Home > Maintenance & Modifications > Fox 2.0 resevoir shocks |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
Can you do pin pin on the rear using any front dampers or just foxes?
13th Nov 2021 9:37pm |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 860 |
Yes any fronts will do. I believe the Gwyn Lewis kits with ome shocks are all pin-pin.
14th Nov 2021 12:25am |
felixp Member Since: 29 Oct 2020 Location: Bavaria Posts: 39 |
I've got the same shocks installed and some roost shields coming my way after worrying that something could break... how exactly did you have modify yours in order to fit? Thanks! |
17th Nov 2021 9:55am |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4401 |
Yes you are right they are pin-pin all around. Great and simple system that works. |
17th Nov 2021 10:04am |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2626 |
first of all, you need the adapters, prolinx supplied mine, they were the prototypes... are you running remote res? that's when its fun (like mine) if they are standard you should be good to go with the adapters. I'd say these are a easier bet... https://www.prolinx.biz/Catalogue/Shock-Ab...GUARDBOOT2 |
19th Nov 2021 11:05pm |
Thanks! I got the remote ones installed.. can you tell me what exactly these adapter do?
23rd Nov 2021 10:20pm |
Take a look here…
The adapters go on the end of the shaft so you have something to mount the shields too. Otherwise they don’t grip / stay on the shaft On the fronts it’s a nightmare, plenty of dremel work was involved to get it to fit with my setup… it’s all adrenaline 4x4 / Gwynn Lewis now |
24th Nov 2021 12:07am |
Ahice Member Since: 28 Nov 2021 Location: VA Posts: 2 |
Awesome set up - looking to do something similar but trying to decide if I want to go with a pin pin rear with a longer remote reservoir or normal rears. Can you share the shock part number you used for the rear? |
28th Nov 2021 9:42pm |
They’re just the standard fronts.
https://www.prolinx.biz/Catalogue/Shock-Ab...FRNTPSSTDA |
28th Nov 2021 10:30pm |
Thanks! I must have missed it in my reading of the thread.
28th Nov 2021 10:35pm |
