Home > Wheels & Tyres (L663) > Wheel spacer which width do you recommend?
Ace7711
Germany
Sorry if someone already mentioned this but which size (width) of wheel spacers work best?
I have the choice between
15mm
19mm
21mm
25mm
30mm
I was thinking of 21mm any advice? I have the 19" gloss black 6 (double) spoke wheels (style6010) on standard 265/65
Any pictures of cars with wheel spacers are welcome. Smile
Thanks 110 D250 SE Tasman Blue, white roof, black pack, advanced towing pack, rear diff locker, driver assist
Post #928344 3rd Nov 2021 11:56am
Tom_T
I have 25mm spacers all round.
Post #928396 3rd Nov 2021 6:52pm
Ace7711
Germany
These look great. Really cool but they do look a bit on the edge. I don't have the "extended" wheel arches and I need to stick to German law. So it looks like 19mm will work best here. Thanks 110 D250 SE Tasman Blue, white roof, black pack, advanced towing pack, rear diff locker, driver assist
Post #928406 3rd Nov 2021 7:30pm
Cedric74
Belgium
And for the 20” ?
With 275 tyre width?
Post #928414 3rd Nov 2021 8:52pm
Defendit..
Netherlands
I have gone with 22mm front & 25mm rear.
https://www.tunershop.de/shop/h-r-spurverb...ery-v.html No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #928586 5th Nov 2021 7:23am
AndrewS
I use 25mm front and rear. In fact I have a spare set that I may consider selling. 130's have feeling's as well you know Smile
Post #928681 5th Nov 2021 6:33pm
TRGRichie
What make? L663 90ht
Post #928741 6th Nov 2021 10:01am
Brulz
Italy
The Front wheel track is: Air suspension 1,706mm and - Coil suspension 1,704mm
The Rear wheel track is: Air suspension 1,702mm and - Coil suspension 1,700mm
So.. The best solution is: 20mm on the front and 25mm on the rear.
Post #929362 11th Nov 2021 6:41am
Ronin
United Kingdom 2014 Defender 90 Puma 2.2 ST Keswick Green
I’m using aftermarket wheels with an offset of ET25. This offset puts the outside face of the wheels in the same position as would a 16.5mm spacer. I also have 275/55R20 KO2s.
The wheels were installed without the wheel arches, and I’ve since installed the wheel arches. The arches add only ~5mm of width per side.
Both before and after the installation of the arches, both front and rear wheels are inboard of the outside of the arches in all three usual suspension height settings.
In fact, I was after a slightly more aggressive look, and am now looking for 15mm spacers. Please let me know where you found them!
Cheers,
Joel Thumbs Up
Post #930854 23rd Nov 2021 5:36pm
PaulSL
Andrew S - where did you buy the 25mm spacers from in the UK? I can only find 30mm.
Thanks
Post #949822 19th Apr 2022 8:48am
Cedric74
Belgium
Do you have an address for the spacer?
Post #950152 22nd Apr 2022 5:41pm
PaulSL
Post #950158 22nd Apr 2022 6:17pm
Defendit..
Netherlands
That is cheap, are they forged ?
Beware when you buy spacers - normal price for a good brand £ 50,- / £ 60,- each. No Mud flaps for my 90.!
Post #950222 23rd Apr 2022 11:46am
PaulSL
They looks to be machined from aluminium billet, but is normal for most modern hub centric spacers. I had 30mm Ternferma brand ones on my Defender that look identical, and had full TUV certification.
Post #950225 23rd Apr 2022 11:59am
rgeezzy
United States
Post #952179 10th May 2022 4:56pm
