![]() | Home > Wheels & Tyres (L663) > Wheel spacer which width do you recommend? |
Tom_T Member Since: 08 Nov 2020 Location: Essex Posts: 87 ![]() ![]() |
I have 25mm spacers all round.
Ace7711 Member Since: 30 Sep 2021 Location: Hamburg Posts: 110 ![]() ![]() |
These look great. Really cool but they do look a bit on the edge. I don't have the "extended" wheel arches and I need to stick to German law. So it looks like 19mm will work best here. Thanks 110 D250 SE Tasman Blue, white roof, black pack, advanced towing pack, rear diff locker, driver assist
Cedric74 Member Since: 24 Aug 2021 Location: LIEGE Posts: 46 ![]() ![]() |
And for the 20” ?
With 275 tyre width? |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 443 ![]() ![]() |
I have gone with 22mm front & 25mm rear.
https://www.tunershop.de/shop/h-r-spurverb...ery-v.html No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
I use 25mm front and rear. In fact I have a spare set that I may consider selling. 130's have feeling's as well you know
TRGRichie Member Since: 03 Mar 2021 Location: Yorkshire Posts: 180 ![]() ![]() |
What make? L663 90ht
Brulz Member Since: 07 May 2021 Location: Brescia Posts: 37 ![]() ![]() |
The Front wheel track is: Air suspension 1,706mm and - Coil suspension 1,704mm
The Rear wheel track is: Air suspension 1,702mm and - Coil suspension 1,700mm So.. The best solution is: 20mm on the front and 25mm on the rear. |
Ronin Member Since: 09 Aug 2012 Location: Kent Posts: 213 ![]() ![]() ![]() |
I’m using aftermarket wheels with an offset of ET25. This offset puts the outside face of the wheels in the same position as would a 16.5mm spacer. I also have 275/55R20 KO2s.
The wheels were installed without the wheel arches, and I’ve since installed the wheel arches. The arches add only ~5mm of width per side. Both before and after the installation of the arches, both front and rear wheels are inboard of the outside of the arches in all three usual suspension height settings. In fact, I was after a slightly more aggressive look, and am now looking for 15mm spacers. Please let me know where you found them! Cheers, Joel ![]() |
PaulSL Member Since: 19 Apr 2022 Location: Warrington Posts: 89 ![]() ![]() |
Andrew S - where did you buy the 25mm spacers from in the UK? I can only find 30mm.
Thanks Last edited by PaulSL on 22nd Apr 2022 7:17pm. Edited 1 time in total |
Do you have an address for the spacer?
That is cheap, are they forged ?
Beware when you buy spacers - normal price for a good brand £ 50,- / £ 60,- each. No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
They looks to be machined from aluminium billet, but is normal for most modern hub centric spacers. I had 30mm Ternferma brand ones on my Defender that look identical, and had full TUV certification.
rgeezzy Member Since: 09 Jul 2021 Location: 44147 Posts: 10 ![]() ![]() |
