Home > Maintenance & Modifications > Puma Heated Seats |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2284 |
Thanks Gents...
All Seats in mine were swapped out by the previous owner so I'm not surprised that there are some non-standard elements. Click image to enlarge LRA I'll order and fit some Mobile Centre Connectors... thanks for the info'. geobloke Thanks also...My Seats are wired to Standard LR Heated Seat Switches so each either on-off / one setting Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
16th Nov 2021 5:23pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4350 |
Ok, so it is still worth tracing the wiring and finding what is between the switches and the heat pads. There may be a control unit/relay to protect those switches which cannot take much in the way of current. If it is a small black and green box then it is possible it is a Mobile Centre kit. |
16th Nov 2021 5:56pm |
Thanks for the advice... geobloke
17th Nov 2021 9:20am |
