Home > In Car Electronics > Britpart DA5717 Heated Seat Kit - WIRING?? |
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 278 |
Evening all
Just fitted the above seat heater kit but sadly the package had it's instructions missing - Grrr! The wiring loom I thought should be straight forward. There is a heavy(ish) red cable fused so that I'm assuming is the positive supply ... and there is a heavy(ish) black cable, presumed to be the negative. In older kits these were the ONLY wires however coming from my loom is also a thin red cable and thin green/yellow cable. Click image to enlarge Can any one comment please? MTIA John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
15th Nov 2021 12:36am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3623 |
The other 2 will be for a thermostat I would think.
15th Nov 2021 7:03am |
Hi Co ... Must be missing your point. The wiring loom already has a relay/thermostat incorporated? 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
15th Nov 2021 10:27am |
Thanks for your reply and image Bodstruck but why would those two be for a switch when the loom already has an On/Off two way switch built in. Think I need to post a more detailed image rather than just the end wires. John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
15th Nov 2021 10:43am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2201 |
watch 46:50 onwards.
Other two are ignition and illumination for switch. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
15th Nov 2021 11:12am |
Sorry folk, maybe I should have posted an image of the whole wiring loom - not just the four wires.
So in the picture below the complete loom has: 4x White connectors (two for each seat) 1x Double On/Off switch 1x Black box (Relay/Thermostat) Click image to enlarge ... and of course the four wires, two of which I'm sure will be the thick Red 12V (VE) Positive and the thick Black being the Negative. Still un-explained the thin Red and thin Green/yellow. Any help greatly appreciated. Thanks John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
15th Nov 2021 11:14am |
Excellent RallySteve - Much appreciated!
Now I can finish off ATB John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
15th Nov 2021 12:32pm |
... and the information is now flowing!
I sent a message to Britpart at 9am this morning not expecting to hear back ... but I've just received the fitting/wiring instructions. Hope this helps others: Click image to enlarge Click image to enlarge Thank you all who replied. Now I can finish the job 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) Last edited by Cubflyer on 20th Nov 2021 8:56pm. Edited 2 times in total |
15th Nov 2021 12:49pm |
Hi folk
Still not wired in the loom yet for the heated seats as I need to modify it. It's so long its not true! Ideally I want to cut at least a metre off the two leads that supply power to the seat elements. I can get the pins out of the four sockets without too much of an issue but I'd like to get new pins to re-crimp the leads to. Anyone know where I can get them please or know the part number (See images below) Click image to enlarge Click image to enlarge Bit of a long shot but "Someone" may know?? Many thanks 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
20th Nov 2021 6:16pm |
