Home > In Car Electronics > Britpart DA5717 Heated Seat Kit - WIRING??
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Evening all
Just fitted the above seat heater kit but sadly the package had it's instructions missing - Grrr!
The wiring loom I thought should be straight forward. There is a heavy(ish) red cable fused so that I'm assuming is the positive supply ... and there is a heavy(ish) black cable, presumed to be the negative.
In older kits these were the ONLY wires however coming from my loom is also a thin red cable and thin green/yellow cable.
Can any one comment please?
MTIA
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #929772 15th Nov 2021 12:36am
Co1
The other 2 will be for a thermostat I would think.
Post #929777 15th Nov 2021 7:03am
bodstruck
Not a brit part kit but in the generic ones I have the other wires are for the switch.
Two position switch, 3 wires to it.
Post #929782 15th Nov 2021 8:52am
Cubflyer
Hi Co ... Must be missing your point. The wiring loom already has a relay/thermostat incorporated? 2010 Defender 90 300Tdi CW (White/1994)
Post #929790 15th Nov 2021 10:27am
Cubflyer
Thanks for your reply and image Bodstruck but why would those two be for a switch when the loom already has an On/Off two way switch built in.
Think I need to post a more detailed image rather than just the end wires.
Post #929794 15th Nov 2021 10:43am
rallysteve
watch 46:50 onwards.
Other two are ignition and illumination for switch.
Post #929800 15th Nov 2021 11:12am
Cubflyer
Sorry folk, maybe I should have posted an image of the whole wiring loom - not just the four wires.
So in the picture below the complete loom has:
4x White connectors (two for each seat)
1x Double On/Off switch
1x Black box (Relay/Thermostat)
... and of course the four wires, two of which I'm sure will be the thick Red 12V (VE) Positive and the thick Black being the Negative.
Still un-explained the thin Red and thin Green/yellow.
Any help greatly appreciated.
Thanks
Post #929801 15th Nov 2021 11:14am
Cubflyer
Excellent RallySteve - Much appreciated!
Now I can finish off Very Happy
ATB
Post #929809 15th Nov 2021 12:32pm
Cubflyer
... and the information is now flowing!
I sent a message to Britpart at 9am this morning not expecting to hear back ... but I've just received the fitting/wiring instructions.
Hope this helps others:
Thank you all who replied.
Now I can finish the job Very Happy 2010 Defender 90 300Tdi CW (White/1994)
Post #929811 15th Nov 2021 12:49pm
Cubflyer
Hi folk
Still not wired in the loom yet for the heated seats as I need to modify it. It's so long its not true!
Ideally I want to cut at least a metre off the two leads that supply power to the seat elements. I can get the pins out of the four sockets without too much of an issue but I'd like to get new pins to re-crimp the leads to.
Anyone know where I can get them please or know the part number (See images below)
Bit of a long shot but "Someone" may know??
Many thanks 2010 Defender 90 300Tdi CW (White/1994)
Post #930518 20th Nov 2021 6:16pm
