Home > Expedition & Overland > Poppy Conversion to a Camper |
Timcat Member Since: 20 Jul 2016 Location: Tanzania at the moment Posts: 1008 |
That’s posh Gary, clever idea. Is it Velcro’d In place ( same as the bug net?)
15th Aug 2021 11:01pm |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2070 |
Hi Tim
There is no vecro used on the flaps - they are all fixed with a long plate, screws and zips ... the bottom of the storm flap has fasteners and I have ordered the same for the window flap too ... We tried it out today in the wind and rain (liquid sunshine in cornwall ) and we are very happy with the results ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
16th Aug 2021 7:54am |
Well we are upgrading the water system in Poppy and have just ordered the chassis mounted 55 ltr tank from Safari Equip. I double checked to see if the tank was compatible with the rock sliders I fitted recently - so hopefully it will all go in with out any conflict.
https://www.safari-equip.co.uk/shop/land-r...ater-tank/ I plan to fit this myself but as has been mentioned before - I am a nurse and not a mechanic so if anyone has done this job before then i would love to have some tips! I have a 30ltr tank in one of the cupboards at the moment which has been working very well, but I would prefer the tank outside to keep the weight low and free up the cupboard for more storage. The water is moved by a small electric pump which feeds to a tap on the back door so the feed line would be shorter and the refill port would be easier to access. I am not sure if I need to move the water pump at the moment but its something that I may look at while fitting the tank. Click image to enlarge Click image to enlarge Click image to enlarge Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
17th Oct 2021 1:10pm |
I have the same Gary, will PM you
17th Oct 2021 5:40pm |
Hi Tim
many thanks -That really helps Hope the trip is going well Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
17th Oct 2021 6:13pm |
Right - 60 ltr water tank fitted - Job Done and Dusted - many thanks for all the help regarding fitting this .. It was well with in my capabilities, but had the usual issues from Tom at Safari Equip - ie no instructions !! - however he was super helpful when I picked up the tank and gave me lots of tips
Pretty daunting to cut the hole for the water inlet though !! measure 1000 times and cut once with my eyes shut ... ! Only one issue which was around the middle fixing mount which had no equivalent mount on the chassis - so had to remove it as it would have rubbed against the chassis - so will go with out for now and see how things go. Click image to enlarge Click image to enlarge Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 Last edited by wyvern on 27th Oct 2021 9:27pm. Edited 3 times in total |
27th Oct 2021 7:12pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10513 |
Nice job you have done there Gary
Was that Poppy i spotted on the M3 on Friday Gary 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
27th Oct 2021 9:00pm |
Hi Clayton
Yes it was -I was taking the scenic route home from Aberdeen I did wave but you were on the other side and gong some what fast !! Looks like you had a great item at Brans Hatch Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
27th Oct 2021 9:24pm |
I thought it was as i put my hand up and saw yours up already, then i saw it was you
Optical illusion thinking Millie going fast was cruising around the 60 mark, nice pace to drive at and yes it does make a change from the M4 - M5 route 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
27th Oct 2021 9:30pm |
Good work Gary, interesting cutting a great hole in your pride & joy!
28th Oct 2021 10:41am |
Pjembe Member Since: 21 Jul 2015 Location: Newbiggin by the Sea Posts: 143 |
Looks great Gary. Really neat job. Like where the filler is fitted as well. Im still thinking whether to have the tank inside or out. no problem when we are in Africa but concerned about possible freezing issues if going into colder climates.
By the way, how are you finding the remap? |
28th Oct 2021 2:39pm |
Hi Paul
The pretext for having the tank outside is keeping the weight low and the cabin warm ... we can aways warm the water if needed, and the tank is quite close to the exhaust so may not be a big issue in the cod - but will see how we get on. We had a tank in a similar place on our previous 110 and never had a problem with the cold with that set up. 60ltr takes up a big lump in the cabin, as the tank is over twice the size of what we had before - so nice to have the capacity to go for a week now when touring with out having to top up. The cupboard the water tank was in has now been reconfigured to take the tools and spares, as well as the trauma and airway kit - the normal day to day first aid kit is still on the back door.. I am debating how to plumb in the new system as that will take some juggling of water lines and may possibly move the pump - but not rushing to change anything just at the moment. Remap is nice and gentle - the pull away is much smoother and there is a lot more low end torque, meaning less gear changing when driving the Cornish roads .. so looking forward to using in on some mountain roads when the time comes - the ability to read all the engine settings is great as well - I am getting to let my geek side out now ! I think that I am getting more MPG as I have kept my normal speed and on the run up and back to Aberdeen seems to be about 30 miles better out of a full tank .. so with the current cost of fuel the remap would have paid for its self after about 80 tanks ! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
28th Oct 2021 4:45pm |
Picked up the real door pockets from Tuf-Trek at the overland show last month - fitted them and they make a nice addition to the back of the waggon - more space to have things accessible from both inside and out when parked up cooking
The water tap flow misses the pouches when in use - so not a problem ! (I keep the washing up kit in that pouch anyway ...so it wouldn't matter too much if it did get wet ) Click image to enlarge Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
29th Oct 2021 3:28pm |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1333 |
Good work and nice to see it evolving
1st Nov 2021 8:48am |
