![]() | Home > Maintenance & Modifications > Defender XS seats |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3615 ![]() ![]() ![]() |
Keep in mind, especially with the seat base, that you have to be able to remove it without cutting the wires... so a connector is needed. By default, seat base and seat back have 2 different connectors, but T connected.
Check the power (current) draw, so to make sure that the connector can easily handle it without melting. I buy in bulk 2 pin connectors (made in China as most other stuff is), but have been pleased with them. However highest power I connect is 25W, which is roughly 2A. But you will need a dedicated crimper, that folds and crimps the pin on the wire (and insulation for anchoring). ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
karlp606 Member Since: 19 Aug 2021 Location: Hull Posts: 302 ![]() ![]() ![]() |
Dinnu as usual you legend
MGCarr Member Since: 18 Nov 2016 Location: Lancashire Posts: 59 ![]() ![]() ![]() |
I have fitted heated cloth XS seats to my 300tdi 90, l find them more comfortable if mounted on Mud seat rails. The incoming wiring goes to the seat back and a wire comes out from the back to go to a plug on the seat base - see pic
![]() Click image to enlarge Sorry not the best pic. The only downside I find is that you can’t fit the original centre seat at the same time. |
Thanks for that I've got a cubby so should be okay with that.
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11062 ![]() ![]() |
I have the half leather XS seats in Millie and all wired in and you can fit the middle seat in between them
![]() Click image to enlarge ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 ![]() ![]() |
I like the idea of a cubby but the middle seat just looks so nice and comes in handy on occasion..
