![]() | Home > Puma (Tdci) > Diff engaged light. |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3652
I have replaced my diff lock switch from below, 2.2. I had to chop a 19mm spanner though to be able to reach and rotate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8489
You can do it from below, a very deep socket helps, but needs space to fit wires in it to! Cheers
| Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025
Many thanks for the reply’s gentlemen will try & source one in Spain.
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
i have problem with one that was slow to operate removed it and placed it in cup with paraffin and has worked for a long time now
That’s not a bad idea, if it were accessible from the top ( if it didn’t mean removing the Planar) I’d give it a go.
But beings I’ve got to do it from underneath I think I’ll try & get one in Spain. Does anyone have a part number for the 2.2? |
also known as High/low on Discovery 2
IGM500011 |
Many thanks Dorsetsmith, much appreciated.
Just an update, did this the other day & as said a cut down 19mm works a treat. It took as long to change the sensor as it did to try & undo the clip into the loom!
One thing I did with ours was to remove the floor pan under the drivers seat so you can see over the chassis rail which makes it much easier. |
| wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2155
Sounds like you are trail blazing for us all in your on the road repairs and how to overcome them !
Been reading the Blog of the trip and its really giving me itchy feet!!! hope your troubles are small and easy overcome Happy travels Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 ![]() |
took me ages to get the electrical clip undone too! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks Gary, just need to get the spares ( when we meet up with our travelling companions) & all will be good. |
| All times are GMT |
