Home > Puma (Tdci) > Diff engaged light.
Timcat
United Kingdom 2012 Defender 110 Puma 2.2 SW Indus Silver
Diff engaged light.
Yesterday it worked & today nothing! Been underneath & plugs still on so guessing the switch? Had to replace the reverse light switch a couple of weeks ago. Been off road all day & I’d the diff locks working. Is it possible to change the switch from underneath or does the cubby have to come out? Have the planar heater under the cubby!!
Post #921055 11th Sep 2021 6:11pm
Dinnu
I have replaced my diff lock switch from below, 2.2. I had to chop a 19mm spanner though to be able to reach and rotate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #921059 11th Sep 2021 6:43pm
jst
You can do it from below, a very deep socket helps, but needs space to fit wires in it to! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #921071 11th Sep 2021 8:20pm
Timcat
Many thanks for the reply’s gentlemen will try & source one in Spain.
Post #921111 12th Sep 2021 8:52am
dorsetsmith
i have problem with one that was slow to operate removed it and placed it in cup with paraffin and has worked for a long time now
Post #921118 12th Sep 2021 9:12am
Timcat
That’s not a bad idea, if it were accessible from the top ( if it didn’t mean removing the Planar) I’d give it a go.
But beings I’ve got to do it from underneath I think I’ll try & get one in Spain. Does anyone have a part number for the 2.2?
Post #921121 12th Sep 2021 9:18am
dorsetsmith
also known as High/low on Discovery 2
IGM500011
Post #921123 12th Sep 2021 9:26am
Timcat
Many thanks Dorsetsmith, much appreciated.
Post #921125 12th Sep 2021 9:31am
Timcat
Just an update, did this the other day & as said a cut down 19mm works a treat. It took as long to change the sensor as it did to try & undo the clip into the loom!
One thing I did with ours was to remove the floor pan under the drivers seat so you can see over the chassis rail which makes it much easier.
Post #924811 7th Oct 2021 8:58am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Sounds like you are trail blazing for us all in your on the road repairs and how to overcome them !
Been reading the Blog of the trip and its really giving me itchy feet!!!
hope your troubles are small and easy overcome
Happy travels
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #924831 7th Oct 2021 10:38am
jst
took me ages to get the electrical clip undone too! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #924855 7th Oct 2021 4:03pm
Timcat
Happy travels
Thumbs Up
Thanks Gary, just need to get the spares ( when we meet up with our travelling companions) & all will be good.
Post #925015 8th Oct 2021 5:44pm
