Home > Puma (Tdci) > Diff engaged light. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3210 |
I have replaced my diff lock switch from below, 2.2. I had to chop a 19mm spanner though to be able to reach and rotate. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
11th Sep 2021 6:43pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7687 |
You can do it from below, a very deep socket helps, but needs space to fit wires in it to! Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
11th Sep 2021 8:20pm |
Timcat Member Since: 20 Jul 2016 Location: Tanzania at the moment Posts: 1008 |
Many thanks for the reply’s gentlemen will try & source one in Spain.
12th Sep 2021 8:52am |
i have problem with one that was slow to operate removed it and placed it in cup with paraffin and has worked for a long time now
12th Sep 2021 9:12am |
That’s not a bad idea, if it were accessible from the top ( if it didn’t mean removing the Planar) I’d give it a go.
But beings I’ve got to do it from underneath I think I’ll try & get one in Spain. Does anyone have a part number for the 2.2? |
12th Sep 2021 9:18am |
also known as High/low on Discovery 2
IGM500011 |
12th Sep 2021 9:26am |
Many thanks Dorsetsmith, much appreciated.
12th Sep 2021 9:31am |
Just an update, did this the other day & as said a cut down 19mm works a treat. It took as long to change the sensor as it did to try & undo the clip into the loom!
One thing I did with ours was to remove the floor pan under the drivers seat so you can see over the chassis rail which makes it much easier. |
7th Oct 2021 8:58am |
wyvern Member Since: 14 Dec 2009 Location: Cornwall Posts: 2070 |
Sounds like you are trail blazing for us all in your on the road repairs and how to overcome them !
Been reading the Blog of the trip and its really giving me itchy feet!!! hope your troubles are small and easy overcome Happy travels Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
7th Oct 2021 10:38am |
took me ages to get the electrical clip undone too! Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
7th Oct 2021 4:03pm |
Thanks Gary, just need to get the spares ( when we meet up with our travelling companions) & all will be good. |
8th Oct 2021 5:44pm |
