Home > Maintenance & Modifications > Springs to use with Fox 2.0
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Greetings gentlemen
Im planning a bit of a suspension refurb for a potential trip coming up. Gwyn's turrets & Sumos, Super pro bushes, FOX 2.0 shocks.
But what springs to run with them? No lift, standard height.
DS Roaming around 🇳🇴🇨🇭
Post #918395 23rd Aug 2021 8:53pm
Sulisuli
I purchased my springs from Alive to put with my Foxes.
Really pleased with the setup, certainly feel the upgraded ARB helps too. Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #918401 23rd Aug 2021 9:04pm
Co1
Same as Suli, eibach springs from alive. I went with standard heigh comfort springs but it obviously depends whether you are looking for comfort or speed.
Post #918451 24th Aug 2021 6:10am
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
Have you got any photos of the stnadard height springs on your 90, Colin?
I saw Alive say once that they reduce the natural rake of the defender by some amount but can't remember by how much.
Also not sure if it was for their standard height or their lowered versions. 4.0 V8 Defender 90
My Instagram
Post #920543 8th Sep 2021 1:05pm
Co1
See below. I know the water one isn’t great, but it shows the height to the wheel arches pretty well.
Post #920554 8th Sep 2021 4:18pm
LJMARSDEN
Cheers Col 4.0 V8 Defender 90
My Instagram
Post #920555 8th Sep 2021 4:20pm
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
Considering these springs, shocks and ARB for my 110 Utility.... I've read loads of the threads on here and yet still cannot decide on standard height or the road spec. Any downside to going for the lower ones at all?
Post #920656 9th Sep 2021 9:32am
jst
depends what you are after ride wise really, what did the guy selling the Fox shocks advise? shocks and springs should be planed as a package working together, am sure they will have some advice for your needs to suit what ever shocks you had. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #920704 9th Sep 2021 2:37pm
scotty38
Thanks but I am thinking of the package as I said. I'm asking on here to see what folk that have had them think about it all for a wider view. If it's just the view of the dealer I need I guess I needn't have posted.... Thanks again.
Post #920712 9th Sep 2021 4:04pm
Co1
Scotty: in this case, a call to alive really would help. Their customer service is superb and they wouldn’t recommend something if it wasn’t right. Give them a call, they really are very helpful.
Post #920725 9th Sep 2021 6:11pm
scotty38
Yes I've spoken with Alive as I was there yesterday, what I'm asking is for some user input. Going lower has been recommended and it's probably what I'll do but just wanted to know from those that have done it if they've seen any downside.
Not quite sure why my "What do you reckon?" question is so much different to everyone elses that appear on the forum.....
Post #920727 9th Sep 2021 6:23pm
jst
Scotty38, apologies my answer has obviously rattled you.
The question from DeeEss appeared to ask what springs were suggested to go with the shocks he had rather than what were peoples experience of certain springs. i was responding to his question. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #920737 9th Sep 2021 7:44pm
Co1
The downside is pretty simple: less ground clearance and less articulation. How much off roading do your do? If you don’t do any then there aren’t many downsides to lowering springs, you might even get better handling and fuel economy.
All I can categorically advise you on in how standard height springs work in a 90, hence advising you speak to Alive. You didn’t say you had previously spoken to them, which is why I suggested you do.
Post #920745 9th Sep 2021 8:29pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I have alive comfort lowering spring s on my 110 and they are superb with the Fox shocks and uprated arb 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #920764 9th Sep 2021 10:02pm
cold
I decided to fit standard Alive springs rather than lowered as there was some noise about issues with propshaft alignment, more in the link below,
https://www.defender2.net/forum/post688961.html
Post #920773 9th Sep 2021 10:51pm
