Home > Maintenance & Modifications > Lowered Suspension & Gearbox/Propshaft Vibration
Scamperbid
United Kingdom 2007 Defender 90 Puma 2.4 CSW Rimini Red
Recently fitted 2" lowering red springs and Bilstein B6 shocks to my 57 plate Def 90 PUMA. This has made a noticeable improvement to the handling, reducing body roll through corners etc. The side effect of this is that I have a vibration that I can feel through the gear stick/transmission around 50 mph in 4th/5th/6th under mid pace acceleration; by 60 the vibration has passed. I had read about this on the forum beforehand so it did not come as a complete surprise and I understand the solution is to have the propshaft re-balanced.
Appreciate any thoughts from members on this topic and if anybody knows of a company that provides this service in Kent/South London area?
Post #688813 25th Feb 2018 5:46pm
Pickles
From my limited knowledge I could be wrong, but I don't think it's rebalancing that you need. I've heard that lowering alters the "angle" of the prop shaft, and so maybe you need a different or an alternative uni joint/propshaft?
Pickles.
Post #688884 25th Feb 2018 9:45pm
Roy5695
Mine does this, but I don't have any lowering or raising of the suspension!!
Would like possible suggestions too! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #688961 26th Feb 2018 11:28am
grafty99
It could be a UJ. The running angle has changed so it may now show up where it didn't before Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #688963 26th Feb 2018 11:53am
Mo Murphy
I'd be inclined to check your Propshaft UJs and your swivel preloads and suspension bushes.
By lowering the suspension by 2'' you have changed the geometry of the suspension, the load borne by bushes changes slightly, your castor angle will change slightly and the Propshafts run flatter changing the locations of the loads on the UJs.
At 11 years old and if it hasn't been done already then you should be considering 4 new UJs, rebushing the suspension and checking and adjusting the preload on the swivels.
HTH
50 Shades of Pennine Grey
Post #689016 26th Feb 2018 3:51pm
roel
At standard height your rear propshaft is almost in line now after lowering your U joint have to work more so I think it will be one off the rear U joints. I suspect the one on the diff side.
The front is getting flatter so I don't suspect the front U joints but I don't rule them out either.
U joints can have a long life if greased and keep moving. If the grease stops moving they wear out quickly. Roel
2003 90 Td5 (2009-now)
Post #689025 26th Feb 2018 4:36pm
Scamperbid
Thanks for the feedback.
Having read the various comments and driven the Landy a few times, I decided to put the standard springs back on the car paired with the new Bilstein B6s. Yes, it sits a little higher however, the ride is less jiggly than with the lowered suspension and still much tighter than before with the old shocks. More importantly, the vibration from the propshaft/transmission has disappeared.
I have therefore concluded that fitting the B6s to the standard spring set up is the best compromise for an improvement in ride/corner wallowing, unless you are prepared to address the vibration issues, which inevitably over time, will create other problems.
I have also become adept at changing springs and have the skinned knuckles to show for it!
Post #690553 3rd Mar 2018 5:23pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Fit bigger anti roll bars front and rear.... body roll removed totally.
Post #690617 3rd Mar 2018 7:28pm
