Home > Maintenance & Modifications > Springs to use with Fox 2.0
Page 2 of 2 <12
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
jst wrote:
Scotty38, apologies my answer has obviously rattled you.
The question from DeeEss appeared to ask what springs were suggested to go with the shocks he had rather than what were peoples experience of certain springs. i was responding to his question.
No probs and apologies here too. Just didn’t want to go lower and then hear of any experiences that make me think twice Thumbs Up
Post #920775 9th Sep 2021 11:25pm
scotty38
cold wrote:
I decided to fit standard Alive springs rather than lowered as there was some noise about issues with propshaft alignment, more in the link below,
https://www.defender2.net/forum/post688961.html
Thanks all appreciated and this above is what I was wondering about a downside and if it was real or not. I can live with a bit less articulation and clearance but anything like this would steer me back to standard height.
After reading the post that spoke about a 2” drop which is a fair bit more than the Alive lowered ones but even so if there’s a chance for this sort of problem I may stick with standard. Now I’m a little more educated I can ask them specifically. Many thanks
Post #920776 9th Sep 2021 11:28pm
iforland
United Kingdom 1986 Defender 90 200 Tdi HT Arles Blue
If you go with the Alive lowered springs (-1") and then add in the isolators doesn't that bring them pretty much back to the same height as standard ones?
Post #920798 10th Sep 2021 8:12am
kenzle8a
Lowering should be at least an (1 inch) so 25mm and the isolators are what 10mm+ give or take, as above seems a waste of money on springs, although looking at the photos of the lowered ones its far more than an inch given the wheel to arch gap as standard. It looks closer to 50 or 60mm lower.
Post #920801 10th Sep 2021 8:22am
Page 2 of 2 <12
