Home > Maintenance & Modifications > Diesel leak by fuel tank.
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Just wondering if there are any typical issues with a 2.2tdci 110 2014 leaking diesel around the fuel tank. Not fast, just a few drips an hour.
I noticed an oily mark on my drive a little earlier and on inspection, the bottom of the fuel tank has a few drips of diesel on it which has dissolved some of the under seal.
As it was getting dark I could only make out that the leak seems to be coming from the drivers side higher up on the tank.
Was filled up full yesterday and I’ve only done about 20 miles so it’s still pretty full. Any ideas welcome if there’s some usual issues. Going to have to get underneath tomorrow.
Post #918579 24th Aug 2021 9:21pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Suspect an issue with the filler hose or breather hose - look under the OSR wheel arch around the filler area as a starter for 10. Rgds.
Chris
Post #918580 24th Aug 2021 9:24pm
pilsburypie
Will do first thing.
Post #918581 24th Aug 2021 9:29pm
wynn153
Very likely breather hose perished - I had exactly the same issue with my 2014 2.2tdci 90. Was only an issue for a day or two after fuelling up until the fuel level was down enough.
Post #918582 24th Aug 2021 9:29pm
pilsburypie
I’ve just read the monster fuel breather pipe thread in the Tdci section. A likely culprit.
Post #918600 24th Aug 2021 10:34pm
Ianh
Whenever I fill up I put my ear to the filler and listen . You can just hear the whoosh of air as the tank is full and pushes air up the filler. At this point you stop and all is well. You have a full tank and no diesel in the filler or breather pipe and no leaks.
Obviously better to fix, and the new style raised breather fitted, which on a 110 is easier than a 90. But a solution that works until you have the time to rectify the fault.
Post #918608 24th Aug 2021 11:09pm
pilsburypie
Good advice. I’ve always been in the habit of brimming cars.
Post #918613 24th Aug 2021 11:48pm
Co1
Mine had this issue but the breather was OK, it was the vent pipe. It is in a crap location and largely inadequate. Check it out before you start replacing the breather itself as it “should” be a simpler repair.
Post #918621 25th Aug 2021 6:01am
pilsburypie
Had a good look this morning. The leak seems to have stopped. Couldn’t see any cracking at the top of the filler of vent pipes due to being covered in under seal.
Going to monitor for a bit and not brim the tank.
At least I now have an idea on what could be the problem should it persist. Must say I have everything crossed as access is crap should I need to intervene with the pipes.
Cheers all.
Post #918664 25th Aug 2021 12:39pm
X4SKP
... Very probably Shocked
Welcome to 'The Club' Thumbs Up
Good Luck with the Fix... SKIP
Post #918672 25th Aug 2021 1:53pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
I just tanked up my 2012 90 and have had the same issue. Front right hand side of the tank. I brimmed the tank, and then heard the fuel peeing out. Rolling Eyes Rolling Eyes Rolling Eyes
See you in the other thread.... Whistle 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTs,
Recaro CSs, anorak, wellingtons
Post #919238 30th Aug 2021 5:36pm
Co1
Have a look half way down this page for my exploits with it:
https://www.defender2.net/forum/topic67542-255.html
Post #919243 30th Aug 2021 6:40pm
