Home > Technical > Anybody swapped out the binnacle clock for something else?
karlp606
United Kingdom 1997 Defender 90 300 Tdi CSW Firenze Red
So my clock keeps losing time - not sure how this is possible as it has a constant live Im led to believe?
Any pointers on this one? As its got me stumped? Cars got a new battery also.
But Im also thinking Id rather have a tachometer/rev counter instead of the clock - has anyone purchased one of the 52mm tachometers and swapped it for the clock?
I understand on a 200/300 tdi it needs to be wired to the altenator?
Post #917660 19th Aug 2021 9:31am
Swapping the dials around is very easy - they're held in with clamps that are fixed from behind the panel. There's no reason why you couldn't fit a suitable rev counter in place of the clock.
There are some pictures and details of a dash that I stripped and rebuilt for my old 90 a couple of years ago here:
https://www.defender2.net/forum/post563004.html#563004 Darren
Post #917683 19th Aug 2021 10:30am
karlp606
Thanks mate, Ive read you need to wire the Tacho onto the W nut of the alternator? Anybody else done this?
Post #917684 19th Aug 2021 10:33am
karlp606
Post #917685 19th Aug 2021 10:36am
Thanks Smile
I've not fitted a new tacho since I owned a Stage 1 V8 more than 20 years ago but that is the general way to go about it. I suspect the most difficult part is just getting to the terminal on the alternator - other than that, it's just a case of running the wire to behind the dash. You can use the existing clock connections for power and lights. Darren
Post #917687 19th Aug 2021 10:45am
Mo Murphy
Yes you do have to wire it to the W terminal, if your alternator has one.
50 Shades of Pennine Grey
Post #917688 19th Aug 2021 10:45am
karlp606
Searching around a few other forums looks easy enough - power/earth will be there already from the clock then wire onto the W nut of the Alternator - you dont have to wire inside the alternator do you? Just the nut outside so I presume it picks up the signal off the nut head??
Post #917743 19th Aug 2021 2:22pm
Mo Murphy
Check you have a W terminal on your alternator before splashing out on a rev counter, not every alternator has one.
Post #917821 19th Aug 2021 7:56pm
L110CDL
I got rid of my clock as i could not put the hour forward or back, it use to take hours to do as the centre thing was not working very well.
I got a boost gauge put in to keep an eye out on how the engine is doing Very Happy Clayton.
Keeper.
Post #917861 19th Aug 2021 9:03pm
