Home > INEOS Grenadier > Episode 9 Interior Design
Page 7 of 11 <123 ... 678 91011>
Bluest
When BMW first introduced that style of shifter, I was asked by someone to move an X5 in a hurry as it was blocking a road following an accident. Being a bit of a petrol head I confidently grabbed the keys legged it to the car, jumped in then could not for the life of me figure out how to get in drive. Push, pull tilt nothing. It eventually went into gear by accident, but no idea what combination of moves achieved it Embarassed At least I didn’t have to run back and ask how it worked Laughing
I should brush up b3fore I take test drive in the Grenadier. 2007 110 TDCi Station Wagon XS
Post #911645 9th Jul 2021 5:15pm
#1784 wrote:
For professional users I'm not so sure the abundance of levers and knobs is an advantage. They want to be able to put their experts (in forestry, power distribution, telecom, survey etc) in a vehicle that will take them to their work location with the least amount of dedicated training and effort as possible. If the same capability (or better) can be achieved with automatically controlled difflocks for example that's always going to be preferred to reduce the stress and competence needed of the driver.
In this day and age, any company that is sending an employee out (as opposed to owner/operators) in either vehicle is going to send them on a training course first; so it's then a question of whether that individual remembers which sub menu, or series of button switches pushes it into "auto" mode, or they look up and flick the diff locks.
I know which ones I would want.
Post #911647 9th Jul 2021 5:22pm
milesr3
2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Been looking round the one they have on display at Goodwood. The interior, particularly the dash, is awful. It looks like an Amstrad stereo from the 80s.
There are lots of bits and bobs poking out underneath and some flimsy plastic trim, like the rear quarter panels. It doesn’t look the finished article to me.
The axles and chassis look serious quality.
Post #911648 9th Jul 2021 5:26pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Post #911649 9th Jul 2021 5:27pm
#1784
Sweden
If it's automatic it's automatic, no need to go into menus to activate, just like L663 center and rear diff, they lock up when required even in normal driving mode.
Not when someone remembers to push a switch or worse forget to unlock them and breaks an axle on tarmac.
I guess it's yet to be seen if Grenadiers diffs are old school hardwired lock/unlock from button/lever or if there is some computer assist involved to protect the driver/vehicle. 110 SE D200 MY21 Tasman blue
Discovery 3 V8 HSE MY06
Discovery 1 V8 ES MY97
RRC 2-door V8 MY83
Post #911650 9th Jul 2021 5:38pm
Philip
Very surprised that, if as appears, the centre diff is open unless manually locked.
Post #911651 9th Jul 2021 5:49pm
Bluest
Thumbs Up I’ll look like a pro next time I use one 2007 110 TDCi Station Wagon XS
Post #911652 9th Jul 2021 6:08pm
County V8
Is that BMW shifter a LHD one how do you push the button with your left thumb as you would if in a LHD car with your right thumb.
Will there be a RHD one or are all BMWs like that??
Just seen another shot answers that question
Post #911653 9th Jul 2021 6:14pm
I wonder how some people manage to get out of bed, washed, dressed and fed to go to work without having to press a few buttons...
L663 no longer has a centre diff, and I wonder what the take up rate on the optional rear E diff is?
Post #911665 9th Jul 2021 6:43pm
Would that be more or less surprised than finding out the Bowler Wildcat chassis really wasn't made of aluminium... Whistle
Rolling Eyes
Post #911667 9th Jul 2021 6:46pm
Philip
Not this again…
Post #911673 9th Jul 2021 7:14pm
Philip
Rolling Eyes
The new Bowler CSP chassis isn’t used in the Wildcat.
Whistle Rolling Eyes
Post #911675 9th Jul 2021 7:25pm
So that's more surprised then... Laughing
Post #911707 9th Jul 2021 10:58pm
Avelingporter
I have one of those shifters in my auto box 3 Series BMW. Maybe a slightly biomorphic design that works with the curves in BMW interior design language that I agree does not match the rest of the Grenadier aesthetic. Morgan have the same problem in the Plus 6. But to use it is excellent and becomes intuitive very quickly.
Post #911717 10th Jul 2021 7:09am
Looking for reasons why it would be so expensive to replace and came across these posts on PistonHeads:
"Whilst trivially easy to replace with another CAN enabled lever of your own design, you "can't" because it's rated SAFETY CRITICAL on the FMEA.
This is because selecting drive or reverse on an auto causes the vehicle to move, which could crush someone against something or result in the vehicle moving un-expectidly and causing an accident. As a result, the gear level unit will use dual channel redundant CAN and is so incorporated into the powertrain safety matrix that BMW simply won't let you replace it, because that system as a whole has had an absolute fortune in money and tens of thousands of hours of validation done on it.
Basically, as per Morgan and everyone else, you use the entire powertrain as supplied or sod off. Those are your two choices...... Wink"
and
"The FMEA includes the entire system chain, from lever to microswitch to microcontroller to CAN etc
You can't change the lever, or change the switches or anything without voiding the safety case, sorry!
(the FMEA includes things like the lever jamming, or the switches jamming, or being filled with spliied coffee, going past a radar transmitter at an airport, you name it, the FMEA and validation are, i can tell you, onerous and rigerous. Its a case of use it all, absolutely unchanged, or use none of it)".
https://www.pistonheads.com/gassing/topic....0&i=60
Post #911723 10th Jul 2021 8:19am
